Help with EVAP Vent control valve SES Code P0455
Guys,
So I tried and bought the Dorman part 911503, no luck. I still have the SES light on for the same code.
I also went and got a OEM new gas cap and no luck. Still the same issue.
What is next?
Would I have to buy the Vapor Canister Purge Valve, Rock Auto has price of $105.79. (STANDARD MOTOR PRODUCTS CP743 Intermotor Solenoid)
What is next?
According to the FSM that is the 3rd component to inspect/replace. Sucks that it's $100 bucks though.
Can you test the one on your car first? I tested my EVAP purge solenoid that I replaced and it was pretty obvious it was bad when I applied 12V+
Guys,
What is next?
What is next?
Can you help me with exact pictures?
http://www.nicoclub.com/FSM/G35/Seda...5_Sedan/ec.pdf
Page 426 shows some of the troubleshooting steps. It's located on the rear of the intake on the passenger side.
UPDATE: Fixed
Guess it was the EVAP Canister Purge valve. After a day or so I checked the car for codes, pending codes and monitor readiness and found everything was all set. I erased the computer again (to double check) and put the original gas cap back on (because aftermarket doesn't have the loop that holds the cap to the car) and after 15 miles or so, the monitors all reset and everything is good.
So for me, my P0455 WAS the EVAP purge canister valve. $40ish from Rockauto for the Dorman part.
I checked the old valve again. I applied 12V to it and while the solenoid clicked, i checked for airflow through the valve by blowing on it (i didn't do this before) and found that the valve was not closing properly like it should. So the original valve did fail even though the solenoid was working.
Nissan/Infiniti issued a warranty extension last year on the Evap system for first gen G's, stretched it to 15 years/150K miles mainly due to problems with filling the gas tanks on a lot of models. It applies even if you're not the original owner and they are still honoring that. Our 05 sedan is 14 years old at this point and 147K miles on the odometer and we took it in a little over a month ago to have the work done. I was the second owner, bought it in 09, and they managed to find me to mail me the letter explaining the change. They had it done in a day and didn't cost us a penny so check your local Infiniti dealer before you spend any money fixing your issue.
Yep we threw the P0455 code, didn't seem to affect the car though when it came up. We would very occasionally have the hard to fill issue and told them that was why we brought it in. The Infiniti dealership here was aware of the extended warranty and fixed the car no questions asked.
Not really. In my case it was the valve at the rear of the car...so I never got that far.
then you say it was the canister vent solenoid that fixed the problem by posting the part number for it when someone asked which part they needed to buy.
And finally when someone asks again, you say the part you needed to change was located in the rear of the car, which is contrary to the fact you stated the canister purge was the fix, in which that part is under the hood as you described.
pretty useless thread imo. Nobody seemed to give a definitive answer for a solution but this one by mustang was very misleading, though likely unintended. I really wonder what part he actually replaced lmaoooo
GnB
Mar 11, 2014 05:20 AM
PearlG35x
Apr 28, 2009 12:58 PM
