service rear end?
Old Aug 22, 2009 | 10:57 AM
JBALLA's Avatar
service rear end?
I been searching and cant find when I need to have the rear end serviced! I just bought the car about 4 weeks ago! I had the oil changed and the trans drained and filled with amsoil trans fluid for j trans! The car is a 04 coupe and has 64,000 on the clock! what milage is it required to be done and whats the best fluid to use to refill it with? Thanks Josh
Old Aug 22, 2009 | 12:56 PM
Silencer_0's Avatar
What do you mean by servicing the rear end?
Old Aug 22, 2009 | 01:44 PM
nghiars's Avatar
He meant the differential fluid^^^ and IIRC its recommended at 30K
Please correct me if I am wrong.
Old Aug 22, 2009 | 04:18 PM
JBALLA's Avatar
Thanks! Whats a good fluid to use?
Old Aug 22, 2009 | 04:44 PM
350 Rookie's Avatar
Do you have LSD? If not, any 75w90 or around there will work
Old Aug 22, 2009 | 05:25 PM
JBALLA's Avatar
OK i do have a LSD! They said use any LSD DIFF synthetic fluid? Any brand recommended?
Old Aug 22, 2009 | 06:43 PM
GJ Hazlett's Avatar
I just did mine today, used Amsoil 75W-90, used 1.5 qts and was a very easy job.
Old Aug 22, 2009 | 06:52 PM
350 Rookie's Avatar
Go with any brand diff fluid with the LSD additive. Brand usually makes no difference. Just make sure it has the LSD additive and its the correct weight.
Old Aug 22, 2009 | 06:55 PM
GJ Hazlett's Avatar
I was told we did not need any additives....you will need a 10mm hex socket to get the drain/fill plug out.
Old Aug 22, 2009 | 07:25 PM
JBALLA's Avatar
Ok cool I was thinking about running the Royal Purple Max gear oil! I have been a fan for sometime of there oils! Heres the link let me know what you think?
http://www.royalpurple.com/gear-oil.html
Muski_G
Dec 1, 2023 11:11 AM
rezendvous420
May 31, 2020 01:26 PM
wuppiedog
Aug 7, 2015 11:16 AM
Ken167
Aug 7, 2015 11:12 AM
atk08
Jul 30, 2015 03:12 PM
