Injen SES exhaust installation help
Old Aug 2, 2004 | 04:22 PM
MyLilBlkG's Avatar
I just installed my injen and it's resting on some black metal bar and it's rattling like crazy. Anyone had this problem or know how to fix it?
Thanks
P.S. I did it without the installation sheet because I don't have one
What are fast car made for? To go fast...SO RACE THE HELL OUT OF IT!
Old Aug 2, 2004 | 04:55 PM
G352NV's Avatar
Never enough
Re: Injen SES exhaust installation help
Hmm I just installed one last week. I didnt read the instructions but I have no rattle. I would say loosen everything up adjust it and tighten it back up.
Old Aug 2, 2004 | 05:36 PM
SunlandG35's Avatar
Same thing happend to me. You need to have them ajust the
pipes a little higher, so that they are not so close to that braket. Easy fix.
Old Aug 2, 2004 | 06:02 PM
jimthegreek02's Avatar
get the car on a lift and loosen everything up and re-tighten in the right positions to where its not resting on that black bar piece. You should be ok.
I called my buddy at INjen and he hasnt gotten back to me yet about the instuctions yet.
Maybe someone has the instruction book that they can fax you from their recent installation ??? Anyone???
Stillen Stage 2 Supercharger, Stillen Front Bumper, Stillen Carbon Fiber Hood, Injen SES Cat-back Exhaust, Injen Cold Air Intake, 19" Axis Hiro Anthracite, Clear Corners
Old Aug 2, 2004 | 06:13 PM
MyLilBlkG's Avatar
I think the problem is that the guy at the exhaust shop didn't install the small gold matal plate things that are suppose to be clamps. I'm not sure if those plates are suppose to be between the pipes or connect the left side pipe to the right side pipe. Anyone know? or has an idea? instructions?
thanks a bunch
Old Aug 2, 2004 | 06:16 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
same thing happened to me and I had a muffler shop weld a hanger in the middle and it lifted the resonators off of that cross member...
2 G or NOT 2 G, there is no question!
Injen SES, Kinetix cats, K&N Typhoon, 19" PIAA Super Rozza's (19x9 & 19x10)
Old Aug 2, 2004 | 07:53 PM
hyperxmr2's Avatar
I had the same problem, i also had to weld in another hanger.
Old Aug 3, 2004 | 04:19 PM
MyLilBlkG's Avatar
I brought my car to my friend's shop and had him flipped the hanger and IT WORKED!! No more rattling...finally. Thank you all that submitted a solution.
Old Aug 3, 2004 | 08:02 PM
glad it worked bro. thanks for buying from me =)
im selling my Stillen S/C if your interested now too
Old Aug 4, 2004 | 01:51 AM
Rever's Avatar
Same rubbing/raddle with the cross member. I'll be visiting Signal Automotove hopefully Wednesday.
04' G coupe/TB/Prem/Sport/Nav/35% Tint/Injen CAI/Injen Exhaust/Clear corners/V5 Plenum/GroundingGear/Nismo caps/Custom TS ECU/Hotchkis Sways
Plates: 1REVER1
Old Aug 10, 2004 | 03:20 PM
The_White_G35's Avatar
I recently got the injen exhaust and i love it but there is a huge rattle when i downshift into high rpm's and also a little rattle that sounds like something is sparking when i put it into gear, my question is on all of yours when did the exhaust rattle on acceleration or deceleration and if you know how i might be able to fix mine, thanx in advance
Old Aug 10, 2004 | 06:47 PM
G352NV's Avatar
Never enough
Sounds like you have the same problem as the others. I would loosen everthing up and adjust it and tighten it back up.
StreetStandard
Exhaust-Vendor
11
Jan 12, 2016 03:21 PM
EPG35
Aug 16, 2015 04:52 PM
Racova
2nd Gen (V36) Sedan
Aug 8, 2015 10:21 PM
Wayne9011
Jul 27, 2015 11:25 AM
sick_sixspeed
Tuner & Dyno
Jul 21, 2015 03:23 AM
