Kinetix Manifold and motordyne plenum spacer?
Old Sep 22, 2009 | 11:09 AM
draco1020x's Avatar
Does anyone know if the Kinetix Velocity manifold and the motordyne plenum spacer are compatible with each other? Or is the Mrev2 and plenum spacer a better combo?
Old Sep 22, 2009 | 11:20 AM
tragedycat's Avatar
Kinetix SSV and Motordyne spacer are not compatible with each other. Get the Motordyne, it's proven to work.
The Kinetix doesn't do anything unless you're FI, and in some cases has been proven to be detrimental to NA cars.
Old Sep 22, 2009 | 01:32 PM
bjquinnIUmed's Avatar
If I'm not mistaken, you completely remove both the stock lower and upper plenums to install the kinetix. Without a stock plenum, there's no use for a plenum spacer, so no, the two are not compatible.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
w4kj4k
Oct 2, 2015 07:57 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
