Gears 1-4 shift fine but when I get to 5th it's like I'm in neutral... :(
5th gear is just reving
this is the 4th transmission i am gettin for my 03 g35 my friend had it he blew the tranny when driving in tiptronic. he replaced it. i baught it shortly after and it blew on me i baught another on and 2 months after i got it its reving in 5th gear idk whats going on. i really dont know what to do or what the cause is
Hi, I have the same issue and I've been quoted $2500 to repair 5th gear (transmission). Did anyone else have this issue and found out that something else fixes it?
It started off slow then I took it in, got the transmission fluid and filter changed, then it slipped all of the time (goes to neutral when over 60mph or shift into 5th using Tiptronic shift).
I still haven't figured out why. Could be torqueconverter, valve body , or the clutch in the trans. Still not sure
My car is doing the same thing at normal speeds - slips into neutral or downshifts when it's supposed to go into 5TH Gear. Infiniti dealership ran codes and drove it and said that "5th gear is shot." Any other fixes known before I spend $2500 for rebuilt transmission? Already changed the transmission oil/filter first.
I would suggest the problem is with fluid level, but if that is correct and you still have slippage it is most likely due to worn clutches for 5th gear, since the other gears do not exhibit this problem. If you are local in the bay area, I have an extra g35 transmission with about 80k miles on it...
Sonicnae@gmail.com sorry for typo
Thanks! How much for the extra transmission? I'm in San Jose. Sonicnae@gmail.comim wondering if AAMCO will install it if you deliver it there (Milpitas).
I will you a PM with the rest of the details and who I would recommend for the repair.
seagrasser
May 3, 2022 09:43 AM
Thebaws11
Jul 2, 2021 11:36 AM
edwinisdumb15
SOCAL Meetings & Events
Sep 18, 2015 06:46 PM
