my car is OVER HEAT
my car is OVER HEAT
hi, I need help, I wish someone can help me if they know anything about it....my G35 is year of 2004 and it a sedan, and today the fan noise is so loud and i found out it over heat, so i add the coolant in the small coolant container....and wait a bit to cool down and drive back home....during the 10 min driving....i saw the temperature is getting up again......and the coolant in the small container is full and the fan is on....and i can't found out what problem
can some one tell me what happen with it...
Or...............just by a new one if you suspect a possible issue and since you already took everything apart you already did all the labor so just replace it. Burb the system of air and cross your fingers.
Its probably your thermostat. GeoBau's thermostat cracked on him a few months ago and his car was experiencing the same symptoms. I would replace it.
Why would you trust a generic mechanic instead of using a trained certified technican who works on nothing but Nissans every day?
Even a Ferrari technican could be at a loss on Infiniti.
marsman328
Northern California
Aug 11, 2015 07:29 PM
vstypicals
Jul 20, 2015 10:55 PM
