AT CHECK LIGHT! help
Old Nov 9, 2009 | 02:54 PM
hyperlite21's Avatar
called the dealer they couldnt tell me what the light meant....took it in for them to run diagnostics what should i expect? anyone else have the AT Check light come on before? they said this light never comes on and thats why they dont know much about it.....
Old Nov 9, 2009 | 03:08 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
damn thats weird.. keep us posted!
Old Nov 9, 2009 | 04:59 PM
rcdash's Avatar
Low fluid or failed sensor? What were you doing when it went off? Could it have overheated? No data = no answer.
Old Nov 9, 2009 | 07:03 PM
so it cost me $134 to tighten a loose grounding wire :-) they say the loose grounding wire caused a malfunction and made the light go off ohh joy
Old Nov 9, 2009 | 07:14 PM
Jeff92se's Avatar
Red Card Crew
Actually it cost you that much for Infiniti to spend 30 min or so diagnoising the problem and actually fixing it. Just to run the diagnostics at the dealer is over $100 I believe. Do a few of those and you could buy your own OBDII scanner like the Autoenginuity.
Which ground was it? I believe there is only one on the tranny. But there are like 5-6 thoughout the engine bay
Old Nov 9, 2009 | 07:31 PM
it was the ground inside the battery side bay
Old Nov 9, 2009 | 07:34 PM
Jeff92se's Avatar
Red Card Crew
Well at least it wasn't a serious problem. Thanks for posting the experience though. I bet you will save alot of other guys money by checking their ground points as a possible cause .
Hasanbaloch
Feb 29, 2024 08:45 PM
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
mtlruss
Dec 20, 2015 01:51 PM
Jadenkid22
Jul 14, 2015 12:33 AM
