rough idle at star up..
Old Nov 13, 2009 | 09:00 PM
g35rida's Avatar
do u guys think it might be an 02 sensor? sense i have the cats gutted n i had an cel light n now i don't. im going under the car tomorrow morning n taking the cats off n check them out but need u guys opinion before i waist my time.
i had the rocky part of the cat removed not the metal mesh i was thinking it might had melted or something?
i really don't know what else to do thanks for all the input so far?
iv already dune the maf , tb, pcv, gaped spark plugs, im running out of options,
Old Nov 14, 2009 | 01:25 AM
Tollboothwilley's Avatar
I'd put money on a vacuum leak. Somewhere along the intake there is a leak. There are 2 vacuum tubes connected to the upper plenum, 1 on the intake tube that connects to the driver's side valve cover, 1 that goes between the valve covers and is connected to the PCV valve.
So, check all 4 tubes plus the NOS port.
Check to make sure all 18 bolts holding the upper plenum to the lower plenum are snug (75-90 INCH pounds is all).
its not going to be your cats.
o2 sensor would have a light on and the o2 sensor down stream is just for emission purposes.
Old Nov 17, 2009 | 05:43 PM
g35rida's Avatar
all the bolts are good tested them already. i haven't tested all the vacuums but i think that its more of an electrical problem, because in the mornings and/or when its sitting for more than an hour it misfires or something.I'm not sure if its misfiring or what it is but it sounds like a subaru...i ran some sunoco 110 leaded fuel.that they had told me it was good to clean the injectors n stuff but it didn't do n e thing but give me that beautiful smell... lol .. i think I'm just gonna go ahead and go stock plugs again.i just didn't want to have wasted that money for nothing on the first ones n then waist them all over again for nothing on the stock ones..
Old Nov 18, 2009 | 11:26 AM
g35rida's Avatar
Old Nov 18, 2009 | 08:57 PM
If its misfiring you need to check your plugs and ignition coils
Old Nov 19, 2009 | 11:01 AM
g35rida's Avatar
thanks ill check and see i got a cel light again thank god now i can put in on the computer.
Old Nov 19, 2009 | 11:03 AM
g35rida's Avatar
thanks for all the input too
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Freeman186
Sep 6, 2023 10:07 AM
KruZZe
Feb 27, 2023 05:04 PM
vamarris
Sep 26, 2015 12:56 PM
doakley92
Sep 25, 2015 12:58 PM
