Tein H tech vs. Tein S tech
Old Aug 23, 2004 | 08:44 PM
johnjunyun's Avatar
I was wondering if anyone here has either of these springs and is willing to give me some feedback. How much lower were the cars after the springs have settled? i know the h tech is supposed to be better quality and have a slightly smaller drop, but i was wondering how good the s tech springs were considering that they are only a few dollars cheaper and offer a drop twice as low as the others. Feel free to make suggestions on what you guys think are better springs, i just need to get a lof oinfo before i spend the money.
Old Aug 23, 2004 | 11:49 PM
tgalvez's Avatar
Re: Tein H tech vs. Tein S tech
I have the H tech and I love them.. It all comes down to what you want. I wanted to keep as much of the stock ride and just get a slight drop. The H techs did everything that I wanted. Many guys here have the S techs and they could tell you all about them. From what Ive heard, they are both great springs, its all about how much drop you want, and what kind of ride you want
Old Aug 24, 2004 | 12:42 AM
Gsedan35's Avatar
What spring to get depends on what you want out of your lowered car and to some extent what amount of drop you wish to have or are willing to have.
Do you have a coupe or sedan?
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Aug 24, 2004 | 03:12 AM
johnjunyun's Avatar
I got a 2004 coupe, I agree with what you guys are saying, i was really leaning towards the h techs because of the small drop, i really dont want to start scraping my new car on every speed bump i pass at work (there are a lot of really really big ones). Thanks a lot for the input, it helped a lot
Old Aug 26, 2004 | 07:45 PM
EverythingG35's Avatar
The S-techs drop the car a bit more than the H-techs, but they're also a slightly stiffer spring, so that'll help keep the car from bottoming out a little bit too... just something to consider...
Justin @
EverythingG35.com
1.888.216.5328
Old Aug 26, 2004 | 08:41 PM
Gsedan35's Avatar
Tein H-tech 350z (fronts are progressive, rears are linear)
358/375 F+14% R+11%
Transfers +3% roll stiffness to front
Tein S-tech G35 coupe & sedan (fronts are progressive, rears are linear)
358/274 R+14% R-18%
Transfers +32% roll stiffness to front
The difference between the two springs besides ride height is that the Z H-tech does not have weaker then oem rear spring rates and does not transfer a ton of roll stiffness to the front. Meaning they do not add understeer to a car that has too much of that to begin with and that the car will handle better.
Edmund Burke
G35 6mt
Old Aug 26, 2004 | 09:09 PM
roneski's Avatar
Devil's Advocate
Are there any camber issues with the H techs?
Ivory Coupe 5AT
Z tube, K&N drop in.
Fujitsubo Y pipe...
Old Aug 26, 2004 | 10:54 PM
Cruz's Avatar
I've had no camber issues whatsoever w/ the Htechs. However, you will need to have the allignment done after installing the springs to get everything back to spec.
XMLM
Old Aug 27, 2004 | 10:18 AM
SFLG35's Avatar
FGC President
think you could do a comparison between the z s-techs and the g s-techs?
im pretty sure im goin to go with the z s-techs cause they are a lot stiffer and that is where i think the car is lacking. also they dont lower the car as much as the g s-techs. thanks man.
Daniel
03.5 5AT DP Coupe
Ground Kit / Z – Tube / Shock Sensor / 5% Tint - 30% Windshield
Clear Corners / L.E.D. Hood Lights / KPTech VDC Memory
KPTech OEM Remote Window Up / Invidia Exhaust
KruZZe
Feb 27, 2023 05:04 PM
prinny
Nov 22, 2015 11:07 PM
AJC128
Nov 1, 2015 11:55 AM
bigmike
Sep 17, 2015 01:58 PM
