Using Revup engine in none revup Z?
Old Dec 17, 2009 | 11:23 AM
350 Rookie's Avatar
I know its not possible just as is. But a buddy of mine blew his motor and bought a revup block by accident. Cant refund. Now, i know that some things have to get swapped over. Were gonna swap over the old heads including the shafts, gears and old chains/guides. Were gonna use the old timing chain cover also. Now is there anything else that needs to be done so the none revup harness/ecu doesnt throw any codes and runs correctly. Also, with swapping the old heads on, is it possible for oil and coolant passeges to not match up or any chance the piston/valve clearence is on the border of contact. I know for a fact this topic has been brought up before but i cant see to find it and I'm actually very busy building another car.
Thanks alot.
Old Dec 17, 2009 | 03:14 PM
Tollboothwilley's Avatar
Wish I had more for you. Check on my350Z and you might find it. More guys do engine work there.
Old Dec 17, 2009 | 04:03 PM
350 Rookie's Avatar
I would but they banned my ip address.
Old Dec 17, 2009 | 04:21 PM
superchargedg's Avatar
I forgot but what did they ban you for and is it a perma ban.
Old Dec 17, 2009 | 04:45 PM
350 Rookie's Avatar
For racial comment against Doug. Hes an ******* to everyone and as soon as i made one comment, he took it personally and i got banned. oh well. Back on topic
Old Dec 17, 2009 | 11:34 PM
which one is Doug?
let me do a little searching for you..if i come across what you are looking for i'll copy and paste.
Old Dec 17, 2009 | 11:41 PM
"the easier thing to do would be to change the front timing cover and use the exhaust timing gears from a standard VQ. then, you should be able to drop the revup motor into your non-revup z.....I may be over simplifying this, but it shouldn't be too hard if you don't want to have the variable exhaust cam timing. "
"If you leave the exhaust cam phasers unlplugged, I believe they will be in a fully retarded position which will cause you to lose some lower and midrange power, but the top end should remain the same.
Of course, you can always swap your front cover, cam gears and covers to the revup engine. Just leave the rear exhaust cam timing sensors bolted into the back of the heads (to keep oil from spewing out of the back of the heads.)
I haven't done it, but evertything should be fine. I have both revup heads and regular heads and there is no difference other than the hole for the cam timing sensor for the exhaust cams."
Old Dec 18, 2009 | 09:55 AM
350 Rookie's Avatar
Hey thanx for the help dude. But in order for the harness to even hook up, you have to have to use the non revup heads because the connectors wont even hook up, even if you extend the PHASE sensor wires.
Besides, the car that the new motor is going in is gonna be up for sale so i cant leave sensors unplugged and any chance of a CEL. I appreciate the research tho. I'm gonna see wht the guy wants to do before i start tearing off the heads. I might take off the timing cover and compaire the gears and cams. the only thing im worried about when swapping over is the actually coolant and oil passeges not lining up and thats not a good thing.
Old Dec 18, 2009 | 09:57 AM
350 Rookie's Avatar
oh and Doug is from CT as well and drives a Black greddy TT Z with built motor. Hes the one that got his rims stolen this summer.
Old Dec 18, 2009 | 07:25 PM
^^^ Doug is a cool guy but if you cant understand his humor and or comments..................well..............but there is no place for racial comments any way........unless you are a racist.
Old Dec 18, 2009 | 10:40 PM
350 Rookie's Avatar
This racial thing is debatable. Please lets get back on topic.
Old Dec 19, 2009 | 12:46 PM
the revup/non-revup heads are almost identical in design. You won't have issues with oil or coolant channeling. The only difference is the timing gear and the variable exhaust valve timing. Since you are using the non-revup wiring harness you won't even have the exhaust cam sensors to worry about. Just get the timing gear set properly and you should be golden.
Old Dec 19, 2009 | 04:05 PM
350 Rookie's Avatar
So swapping the heads and timing parts will work? If im gonna go as far as changing the timing gears, i might as well go ahead and change the heads so the connectors will match up in the back.
Freeman186
Sep 6, 2023 10:07 AM
alessandro
Oct 8, 2015 09:29 AM
Joe Gargano
Sep 18, 2015 11:17 AM
AT23
Sep 15, 2015 07:44 PM
AuAltima3.5
Sep 13, 2015 10:53 AM
