Leaking valve cover write in campaign
Have Technical Questions or Done Modifications to the G35? Find out the answer in here!
(View All Posts)
Aug 15, 2012 | 10:48 PM
AARONHL
Oct 2007
ɷCONNECTICUTɷ
The O-rings were put in there from the factory so why can't they be removed? It the valve cover molded around them?
AARONHL
Find all posts by AARONHL
Catch can/Crankcase venting?
Herbbie Hablib
Forced Induction
06:17 PM
FS:
NEW OEM radiator drain/bleeder gaskets
AuAltima3.5
Cooling
10:46 AM
FS:
Fumoto Oil Drain Valve with lock
johnadlertech
Engine - Complete Motors
12:45 PM
Oil leaks from multiple locations
UT G35
03:58 PM
Tags
03
2004
cost
cover
covers
g35
gasket
gaskets
infiniti
leaking
leaky
repair
replacement
replacing
valve
Back to Subforum
View Next Unread
P1283 - Air fuel ratio (A/F) sensor 1 (Bank 2) lean shift
03:08 PM
