what mods i need to gain 50hp?
Old Jan 1, 2010 | 07:43 PM
rob g35's Avatar
guys i got a stock g35 how can i put like 50 hp?
Old Jan 1, 2010 | 07:50 PM
akk08's Avatar
vortech supercharger
Old Jan 1, 2010 | 07:51 PM
ttrank's Avatar
Grocery getter
Stillen will give you over 100 with the right stage and is easy to install.
As for bolt-on, that's a lot of work but can be done. Might as well go with spray or boost.
Old Jan 1, 2010 | 07:56 PM
rob g35's Avatar
and how much does this stillen cost more than a supercharger?
Old Jan 1, 2010 | 08:23 PM
davidxu's Avatar
uhh if you didnt know, vortech and stillen are brand names. both akk08 and tim (ttrank) are talking about their superchargers...
you can buy them on g35parts.com
stillen supercharger is 3800 but i don't know what stage it is
vortech supercharger is 5800
also.... why post it in the canadian marketplace?
shouldn't you be posting in the tech area?
Old Jan 1, 2010 | 08:28 PM
4DGS's Avatar
David, are you referring to the top mount Stillen?
I suggest looking into the Procharger. It's easy boost.
Old Jan 1, 2010 | 08:47 PM
davidxu's Avatar
yea, i was referring to that one.
Old Jan 1, 2010 | 11:43 PM
bigc's Avatar
Wings Nation
it will be hard to get 50hp out of bolt-ons - its possible, but expensive. if you just want 50hp, NOS is probably the most cost effective way to reach that goal. Read up in the nitrous forum over on my350z (don't post any questions until you've searched around) for info on basic setups. A lot of guys have pieced together reliable kits for under $1,000.
If you want to spend a little more, you can go with a supercharger like the guys above have mentioned. Used kits go from $2,500 - $3,500 depending on the add-ons, and you can get a new, full vortech kit from some of the vendors on here for around $4,500.
Old Jan 2, 2010 | 02:00 PM
G-MAN (CANADA)'s Avatar
NOS is useless if you use your car for everyday driving and its illegal to have the bottle hooked up in your car, at least if your boosted you can have that extra power whenever you want.
Old Jan 2, 2010 | 03:32 PM
liche's Avatar
True, but both are completely different superchargers with totally different characteristics.
Also, you'll find in practice, that once you go the FI route, you'll spend at least twice the amount of the kit once you figure in install, tune, gauges, and other features.
Also, 50hp is not much. I don't think you'll really feel the difference. I had all the bolt-ons originally and other than "sounding" different, i don't think it really made much difference. If you want to actually "feel" the difference, you got to go boosted, or do something drastically different with the engine.
Old Jan 2, 2010 | 03:52 PM
rob g35's Avatar
ok guys now i got more information thanks a lot but now whats boosted its different than a superchaged? sorry guys i really dont have so much information about adding power to my car thats why m asking ur help..and is it normal to drive a supercharged or whatever boosted if i use my car as daily drivin??what about fuel economy it do make a big difference??
Old Jan 2, 2010 | 04:10 PM
kennymo's Avatar
boosted can be refered to for both superchargerd and turbod. yes you can drive it daily. fuel economy will go down a little
Old Jan 2, 2010 | 04:56 PM
liche's Avatar
"Boosted" basically just means your running positive pressure in your manifold. Higher pressure means more oxygen can be delivered to your engine (the air is denser) and burn more fuel.
The air is typically compressed through the use of either a turbo charger (driven by exhaust) or supercharger (driven by engine directly via belt etc...)
A turbo or SC can be used as a daily driver.
Fuel economy generally goes down. Some people will say efficiency is increased through a SC, but this doesn't take into account the "fun factor" which basically means you boost a lot which means more fuel!
I get about 10-12 MPH city driving in my car which uses a Vortech SC. Highway is about the same as stock.
Old Jan 2, 2010 | 08:45 PM
gabe3d's Avatar
50 extra whp is a lot and almost anyone should feel a difference while driving.
Like many have said above, the most cost effective way of getting there and exceeding 50whp will be to buy a supercharger. On the VQ35 platform with simple bolt-on mods you won't get there, unless you start touching the engine internals.
Old Jan 2, 2010 | 10:07 PM
rob g35's Avatar
guys what is skyline gt 350?
