CEL's
Old Jan 3, 2010 | 12:06 PM
SirDriftsALot's Avatar
Exclamation CEL's
So I did my motor swap just stock cuz I blew min. So the new one came up with check engine lights saying vvt was off and cam position sensors. Does that mean my cams are bad or just the sensors?
Old Jan 3, 2010 | 12:09 PM
Also I live in new mexico and the motor came from cali so I don't know if timing is pulled on that motor or not but I figured the ecu was all that controlled that so I'm not sure what to do
InShAllAh's Avatar
Just the sensors. Check the actual connector because the connectors suc. If not try replacing the sensor, take it off your old motor is like a 2 sec swap.
Old Jan 3, 2010 | 12:11 PM
Sick thanks man. Now what about the timing cel...
Old Jan 3, 2010 | 12:23 PM
InShAllAh's Avatar
One fault at a time bro. Fixing that one issue might solve two problems.
Old Jan 3, 2010 | 12:26 PM
Alright thanks, ill try that out and see.
Old Jan 4, 2010 | 12:20 AM
Tollboothwilley's Avatar
+1. Those are both related: vvt (variable valve timing) and cam sensors. Very likely could fix both with just the sensors.
Old Jan 4, 2010 | 07:07 PM
InShAllAh's Avatar
any update?
Old Jan 5, 2010 | 10:50 AM
well i started by just dis connecting them and tried cleaning them and still no change, i think i need to reset my ecu though. but if that doesnt work do i gotta swap the whole cover or can i just pull the sensors and swap them??
Old Jan 5, 2010 | 04:48 PM
just pull the sensors and swap them. Your cams are not going to be the problem. I am 99% certain of that. They don't really go bad. Its the sensors. If you took those off to clean them you shouldn't have any trouble replacing them either.
06g35
Feb 14, 2022 05:59 AM
brownie
Nov 25, 2015 12:50 AM
G35VSHNG37
Oct 25, 2015 08:43 PM
flytim3
Sep 5, 2015 01:23 PM
