This cant be good... Coolant/Antifreeze
UPDATE: I found my car under a hill of snow, once I got the hood open (battery was frozen, no power to the car) I discovered it was PACKED from the ground up with ice and snow, I just got the parts I needed (fusible link broke on the positive battery cable) and got the car cranked over and running, I am now waiting for it to defrost itself so I can actually see into the engine bay... There is A LOT of a green/brown fluid under my car most of it is slush (its warm today 29*F). Its been running for about 25min now, the last time I checked the temp gauge was reading in the normal temp range. I am thinking if I can get the car and engine defrosted I should be able to trouble shoot it tomorrow...
when you fire it up... pay attention both outside and inside the car.
make sure there is nothing immediately gushing/coming out...
then make sure it doesnt over heat while driving to a shop if you can do this yourself.
BUT THE FIRST STEP IS TO FILL THE FLUID UP BEFORE DOING ANYTHING.....LOL
I believe the freeze plugs are on the back side of the motor.
Also, your car will be ok for a short period of time depending on where the size and location of the leak. My radiator was leaking but I was able to make a 30 min trip to the house without causing the temperatures to spike at all...long enough to get it safely home and replace.
