How to replace an OEM ECU for my 03? HELP!
Old Jan 5, 2010 | 08:45 PM
Vash's Avatar
The dealer said I have a bad ECU. SES lights won't turn off.
I was wondering what the steps are on replacing an ECU?
Which ECU will work for my 2003 G35 Coupe?
Do I need to get my keys re-programmed?
Thanks in advance
Old Jan 6, 2010 | 12:50 PM
Jeff92se's Avatar
Red Card Crew
You can source another ecu possibly. Get the appropiate 6mt or auto version. But you'll need to have the keys and fobs reprogrammed by the dealer as well as getting the ecu tied to your particular car.
Old Jan 6, 2010 | 01:34 PM
Vash's Avatar
Thanks
Old Jan 6, 2010 | 02:51 PM
Vash's Avatar
Can I use a 2004 ECU on my 2003?
Same body style and both are auto.
Old Jan 6, 2010 | 02:59 PM
Jeff92se's Avatar
Red Card Crew
You're going to have to verify ecu part numbers with the dealer before purchasing. ESPECIALLY if you are a sedan.
Old Jan 7, 2010 | 03:30 PM
Vash's Avatar
I just removed my ECU, it's more of a pain than I thought.
MEC31-912 A1 3324
Do I need the exact part number?
Old Jan 7, 2010 | 07:42 PM
sliderg35's Avatar
MEC31-912 A1 3324
YES! The 2003 Sedan had two different versions of ECU. The earlier one had completely different connectors. You have to be very careful here, or you won't be able to make your car run without a full re-wire of the harness.
Old Jan 8, 2010 | 01:57 AM
Vash's Avatar
Thanks,
My car is a 03 Coupe.
Does that matter?
Old Jan 8, 2010 | 02:37 AM
Tollboothwilley's Avatar
03 coupe will be interchangeable with any 04 ECU
Old Jan 8, 2010 | 07:59 PM
Vash's Avatar
VERY NICE!
Can someone verify this before I buy an ECU?
Has anyone ever done this before?
Thanks so much.
Old Jan 8, 2010 | 08:13 PM
Jeff92se's Avatar
Red Card Crew
You really should be asking the dealer.
Old Jan 9, 2010 | 12:23 AM
Trust me. Coupe got the newer ECU in 03. Its the same ECU for sedan and coupe in 2004. In fact, it will be the same ECU for any 5AT from 2004-2006. Wiring harness might be a little different for the TCU (tranny) in 2004.5 models since the TCU is inside the trans.
Call Tony @ riverside infiniti and he can verify this for you
Old Jan 9, 2010 | 09:29 PM
Vash's Avatar
Thanks
I'll give Tony a call.
Hasanbaloch
Feb 29, 2024 08:45 PM
mike730
Jan 12, 2018 04:25 PM
bTanz
Oct 15, 2015 02:31 PM
kenthung
Jul 21, 2015 05:56 AM
