31lbs. OEM Dual Mass Flywheel vs 27lbs. Single Mass Flyweel?
Old Oct 20, 2013 | 09:47 AM
  #31
QX1's Avatar
QX1
You cannot install flywheel improperly?
There is only one way to install flywheel, otherway you car will not start?
Originally Posted by Stillen06coupe
The OEM one you bought has a lot of chatter and shaking? Sounds like that Chinese was a bad choice. OEM should have minimal chatter and not vibrate in reverse. Or it was installed improperly. All aftermarket will sound like a cement mixer. It all depends on how much chatter you can tolerate when it comes to aftermarket ones. I can't promise the Exedy won't be loud
Old Oct 20, 2013 | 01:55 PM
  #32
Texasscout's Avatar
The advantage that nobody has talked about in the JWT, is that when and if it ever needs a resurface, you just replace the friction surface, no need to machine it.
Old Oct 22, 2013 | 09:32 AM
  #33
LoSt180's Avatar
I would think that a heavy single mass flywheel would be a recipe for breaking something. The reason heavy flywheels are dual mass is to avoid shock to the drivetrain. Drop the clutch on a heavy solid flywheel, say goodbye to gears. I could be wrong, but I don't think a sprung clutch disk would absorb that much, that's why they're paired with a lightweight flywheel.
Unsprung clutch disks are paired with the OEM dual-mass.
Here's an animation about what's going on inside a dual-mass flywheel:
Old Oct 22, 2013 | 09:39 AM
  #34
Stillen06coupe's Avatar
Correct me if I'm wrong, but isn't that why they have harmonic balancers? I mean plenty of cars use single mass flywheels and none are lightweight. I found this info just now....
http://www.directclutch.com.au/flywh...onversion.html
yosip1115
Forced Induction
Jan 28, 2016 02:51 PM
Spartan268
Aug 20, 2015 09:14 PM
TurboEE
Jul 31, 2015 10:41 AM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
