Engine pulley making noise
Old Jan 16, 2010 | 05:58 PM
FavreOnSunday's Avatar
I have a pulley making a ringing type noise. Is this a common problem? I'm trying to figure out which 1 it is. Any ideas?
Old Jan 17, 2010 | 12:00 AM
Tollboothwilley's Avatar
Depends on which one. You don't want any of them making noise, but some are worse than others. My guess is that your AC idler pulley has a bearing going out.
Old Jan 18, 2010 | 01:19 PM
liche's Avatar
To figure out where the noise is coming from just get a small piece of hose (like garden house) put a funnel in one side.
Hold hose (funnel end) to ear and then just point around with other end of hose at various pulleys.
You should be able to isolate where the noise is coming from.
This is an old school mechanics trick!
Old Jan 18, 2010 | 06:20 PM
rob dog g35 cpe's Avatar
same prob
I have this same prob. It only rings when I cut the climate control on. If this is a pulley prob, would changing to aftermarket unorthodox pulleys eliminate this?
rezendvous420
May 31, 2020 01:26 PM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
Jussaku
Jul 29, 2015 11:45 AM
joedaddy1
Jul 28, 2015 02:58 PM
