04 G35, air rushing sound at PCV
Old Jan 28, 2010 | 01:36 PM
A.Chambers's Avatar
I just noticed this the other day after Infiniti replaced the valve covers under warranty because of leaking gaskets. With the car at idle, it sounds like there is a vacuum leak on the passenger side of the engine. After narrowing it down, it is coming from the PCV valve on the passenger side valve cover. I dont ever remembering hearing the sound before, but it is definitely there now. Is this normal? Any of you guys with a Z or G noticed this? Anyone willing to start your car and check to see if you hear it? It sounds like it is pulling A LOT of air from the valve cover.
Old Jan 28, 2010 | 03:45 PM
Tollboothwilley's Avatar
Did they replace the PCV valve when they did the valve covers?
According to the FSM you should be able to hear a hissing sound coming from the PCV when operating correctly.
I can hear mine.
Is your idle normal? If you're PCV valve hasn't been changed you might consider doing it. PM if you need a link to a service manual.
Old Jan 28, 2010 | 03:49 PM
A.Chambers's Avatar
I doubt they replaced it. I decided to go and get a new one tonight, <$15 and 70k miles, it wont hurt.
Idle is normal, as in, it idles around 600 rpm. BUT, I can feel it almost missing sometimes, tach doesnt bounce but I can feel the car kinda shiver if thats the right word. I gave them 6 new spark plugs to put in when they replaced the valve covers hoping that would take care of it. That didnt seem to help at all. I am going to check though and make sure the new plugs are in...If I can tell by looking at them.
Old Jan 28, 2010 | 03:55 PM
Idle should be 700 rpms +/- 50 rpms according to FSM. You'd notice if it was low because it starts to putter.
Old Jan 28, 2010 | 04:02 PM
A.Chambers's Avatar
its definitely closer to 600. I do have a plenum spacer on there and have cleaned the throttle body (that resulted in a 1200 rpm idle) it was nasty as hell. After the ecu, throttle position, and air idle procedures it came back down to 600ish, but I guess 650 is 700 -50 so I am thinking it is in spec. I will try another idle air learn.
I wouldnt call what it does a putter, more of a little shake every couple seconds while sitting idle.
Old Jan 28, 2010 | 04:13 PM
you're fine if it seems normal. lower than normal idle and you will know. Feels like the engine is struggling to stay alive.
Old Jan 28, 2010 | 07:36 PM
A.Chambers's Avatar
so after checking the idle on the way home from work, and redoing the idle reset procedure, it is definately idling close to 600. I would guess 625, but is the tach that accurate? I wouldnt think so.
oh and no parts stores around here have the pcv valve in stock.
Old Jan 31, 2010 | 11:25 AM
pwebb's Avatar
"they all do that"
stock tach isnt perfect. it will read slightly off
Old Jan 31, 2010 | 11:44 AM
OCG35's Avatar
the hissing is completely normal... if you previously had cover on, you probably never noticed the sound...
Old Feb 3, 2010 | 11:22 PM
only cost me $11.50 or something like that at the Nissan dealership...get one there. They should have one in stock.
TWASkyliner
Feb 8, 2020 08:00 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
lemmy999
Jul 25, 2015 12:13 PM
laksjd84
Jul 24, 2015 05:12 PM
vstypicals
Jul 20, 2015 10:55 PM
