G35 coupe metal rumbling/rattling noise during acceleration - VIDEO!
Old Nov 5, 2010 | 04:37 AM
jin22gt's Avatar
R u guys talking about the shield over the two stock cats? Mine is all rusted and cracked. Having alot of rattling sound.
Old Jul 18, 2012 | 09:12 AM
Sacch's Avatar
I was having a similar problem, i removed my heat shields over the cats, but the noise is still there. Is there any other sheild that could be loose?
Old Jul 18, 2012 | 09:27 AM
NicooG35X's Avatar
Usually those shields fall apart except around the O2 bung. Be careful not to damage or pull on that wire. A good note too if u pull them off buy a man of the good spray can style rhino liner like the 8-11 dollar one and spray the floorboard and part of the firewall. It will deflect heat from the cabin and keep temps down next to ur transmission since the side pump and pan are right next to ur cats. Very cheap cost for a lot of preventive maintaince.
Old Nov 5, 2012 | 02:52 PM
deleo14's Avatar
my noise started @ 95000 miles and took it into dealer before warrante expired. they said that my cats are clogged with the honeycomb material that is inside of them. Only thing to do is replace cats. I now have 166000 and have NOT ever replaced them. I'll wait till my check engine light goes on and I cant pass emissions before a spend a **** load of money on new cats
Old Sep 16, 2015 | 02:12 PM
Kushwant_r's Avatar
Answer
I have 2008 g35 sedan....the shield is the one underneath the rear passenger side area..above the drive train coupler.. Has three bolts on each side and and a small strut underneath it. Remove the strut and pull out the shield. Sound went completely away after removal
Old Nov 5, 2018 | 02:55 PM
japles's Avatar
Infiniti G35 Coupe
same tho
Originally Posted by TheKnite
Could you explain where exactly this shield is. I have an 04 coupe and I only hear this when accelerating, and the sound echos off of a divider or other cars next to me. In neutral revving does not make the noise, only as I accelerate.
Any help is appreciated. Thanks.
what was the resolution of this problem? I think I have the same issue.
Old Apr 3, 2021 | 04:29 PM
pedrov35's Avatar
g35
got the same issue myself, any resolution to it??
Old Jul 30, 2021 | 04:08 AM
HeyZeus420's Avatar
2006 G35 coupe premium
I'm checking my heat shield in the morning
Old Mar 2, 2022 | 03:35 PM
nataliyavel's Avatar
Infiniti g35
I had the same problem with my Infiniti I took it to jiffy lube they said it was some kind of plate not sure the name of it but it had some loose bolts and would cause the noise whenever I went 40 miles or faster. They screwed on the bolts tighter and the noise stopped. It was free. I’m so glad I went in for an oil change and also that noise problem. So glad they did it for free. I was thinking it was a big problem that would cost a lot of money. Most likely it’s something loose. Good luck.
richyun6
Jul 17, 2014 01:21 AM
Geewhiz420
Jan 3, 2013 02:18 AM
BlackWindEXE
Dec 4, 2006 11:49 AM
JOHNG35
Jul 30, 2003 08:12 PM
