AC Clutch Problem / Loose Belt
Old Mar 4, 2010 | 10:30 AM
Johnnyone's Avatar
So the in the last two days I've noticed that I have a loud roar from a slipping belt when i first start the car and notice that i get the sound every once in awhile when i disengage my clutch.
After looking at the issue, my cousin and I determined that the AC Clutch needs to be tighten down, so i grab a 10mm and try to tighen it, it turns but never wants to tighten itself.
My question to you all is,
Could my AC Clutch be going bad or do I just need to find a way to tighten the bolt. You think i just need to retap the thread to the AC Clutch?
Anyone else experience this? I've searched and some old thread came up but no resolution.
Here is a link to the to the AC Clutch, item 10
http://www.infinitipartsusa.com/part...layCatalogid=0
Old Mar 4, 2010 | 11:00 PM
geew1z's Avatar
I have no idea why you think you need to tighten the ac clutch???? You should just tighten the tensioner pulley for that belt.
Old Mar 5, 2010 | 09:56 AM
Johnnyone's Avatar
Yea after looking at a diagram i now see that the pulley.
Looks like i will have to remove the underbody covering to get to it though.
Old Mar 5, 2010 | 04:35 PM
geew1z's Avatar
Yeah you will, and then loosen the bolt holding the pulley on and then just turn the screw to tighten it.. Once you understand what to do, its a really nice design and very easy to tweak.
Old Mar 10, 2010 | 10:46 AM
VQEric's Avatar
Something else to keep in mind when adjusting the AC belt tensioner is that the "ears" on the tensioner bracket can get tweaked from overtightening/overuse and then you lose some of the adjustment travel. Happened to mine and I couldn't get the belt tight enough. My dealer said it's common and he won't even sell the pulley by itself because of that...only sells the whole bracket/pulley assembly.
Old Mar 12, 2010 | 09:59 AM
ttrank's Avatar
Grocery getter
+1 to what everyone else has said. There is no reason to do any more than tighten the belt.
zcherub
Aug 30, 2015 05:04 PM
G35CO
Aug 25, 2015 02:00 PM
D1dphresh
Aug 7, 2015 06:10 PM
atk08
Jul 30, 2015 03:12 PM
