Need tech help please
Old Mar 6, 2010 | 10:53 PM
Dragon350GT's Avatar
Can someone please tell me where to find the Crankshaft position sensor. I don't know where to find it and everytime I search it pulls up page upon page of camshaft bull****. Apparently the computer can't differentiate between the two.
Old Mar 7, 2010 | 12:39 PM
Any chance you could post the image or a link to it. I just can't seem to find one. Also it is for the 5AT if that changes anything.
Old Mar 7, 2010 | 01:25 PM
Texasscout's Avatar
From the Service manual page EC 258: http://www.g35frenzy.com/forum/showthread.php?t=1044
DTC P0335 CKP SENSOR (POS) PFP:23731
Component Description ABS003CW
The crankshaft position sensor (POS) is located on the oil pan facing
the gear teeth (cogs) of the signal plate. It detects the fluctuation of
the engine revolution.
The sensor consists of a permanent magnet and Hall IC.
When the engine is running, the high and low parts of the teeth
cause the gap with the sensor to change.
The changing gap causes the magnetic field near the sensor to
change.
Due to the changing magnetic field, the voltage from the sensor
changes.
The ECM receives the voltage signal and detects the fluctuation of
KruZZe
Feb 27, 2023 05:04 PM
prinny
Nov 22, 2015 11:07 PM
AJC128
Nov 1, 2015 11:55 AM
bigmike
Sep 17, 2015 01:58 PM
