My car is leaking something, any idea what?
Old Mar 8, 2010 | 03:02 PM
OCG35's Avatar
Originally Posted by Jeff92se
This one?
I thought that statement was odd too. Neither the AT or manuals had external oil coolers.
You can upload files if it's small enough. Just have to scroll down to the manage attachment options
you just posted the same pdf I did...
Old Mar 8, 2010 | 03:03 PM
OCG35's Avatar
Originally Posted by cpufreak3
Now I'm 90% sure it's oil, and 100% sure it's not from the filter/drain plug (I checked).
Can I drive around without the plastic cover underneath?
do you have an oil catch can?
Old Mar 8, 2010 | 05:01 PM
cpufreak3's Avatar
No idea? I'm not too technical with actual parts. I can only do basic things like oil changes and spark plugs.
Car is completely stock. I'll get under it again Wednesday when I have some free time with some pictures and report back to you guys. Thanks
Old Mar 8, 2010 | 06:11 PM
OCG35's Avatar
if its stock, you have no catch can... I only mention it because depending on what can, they can seep from bottom and create a mess that is initially decieving as to source...
Old Mar 8, 2010 | 07:37 PM
bythabay's Avatar
power steering fluid?
Old Mar 8, 2010 | 09:12 PM
cpufreak3's Avatar
Assuming I know who this is, I just want to say thanks for all the vids.
Pretty much all the maintenance I've done is due to your help!
I'll get back to everyone once I narrow things down so I don't keep everyone guessing.
Old Mar 8, 2010 | 10:28 PM
Tollboothwilley's Avatar
power steering/engine oil/transmission fluid
each could potentially leak in the engine bay. Color and smell are very important.
Old Mar 8, 2010 | 10:35 PM
j 4 lD's Avatar
when you drive it for a while, do you smell a burning smell like oil is burning?
Old Mar 8, 2010 | 11:12 PM
cpufreak3's Avatar
No burning oil smell.
When I start the car though, it smells like oil but goes away.
Old Mar 9, 2010 | 12:12 AM
OCG35's Avatar
speaking of chasing a leak... what ever happened to the frozen coolant leak guy?... did that one get resolved?...
Old Mar 9, 2010 | 12:50 AM
bythabay's Avatar
Thanks; and you're welcome
Old Mar 20, 2010 | 08:21 PM
cpufreak3's Avatar
UPDATE: So the problem looks to be the oil pan gasket.
I took a quick look online, does the gasket come in two pieces? Thanks
Old Mar 21, 2010 | 04:37 PM
Blue Dream's Avatar
I drove ttrank's car solo
Sorry, don't know but I'm curious. Mine looks like it has RTV or something similar. Stock pan, never been messed with. I'll look at the FSM to see if it specifies what is on there.
Old Mar 24, 2010 | 01:39 AM
pyrate88's Avatar
Looks like no oil pan gasket, just RTV on lower part of pan. Upper part has crank seals also. I figured you were talking about the lower "pan" though.
Old Mar 24, 2010 | 09:28 PM
  #30
cpufreak3's Avatar
Yeah, it seems the RTV is a liquid gasket, so I'll have to give that a try.
The seals on the upper part - would that affect me?
