Oil Analysis - first 2600 miles on the turbos...
Old Sep 17, 2004 | 10:39 PM
GurgenPB's Avatar
Hey Guys... got this a while ago. I guess my bearing wear too fast with this oil. Trying 15w50 now... will see what happens....
Gurgen
Old Sep 18, 2004 | 07:51 AM
neffster's Avatar
Re: Oil Analysis - first 2600 miles on the turbos...
Boss...
If I read your report correctly the oil 15W-50 is what the report says you're currently running. Do you plan on going to a "thinner" or "thicker" oil? Just curious...
Old Sep 18, 2004 | 12:00 PM
jjellyneck's Avatar
Yes, the oil weights contradict one another.
A couple of the tubo cars I've owned had later moved their recommended oil weights to 0W30 or 0W40, and synthetic. This was because they found that the thinner oil was better for circulation through the oil lines and it was better for cold/cool startups. Better/bigger oil lines and oil circulation through the turbos might not make that a big deal--depends on your oil lines and type of turbo that you're running. Just my 2 cents.
'04 6MT coupe
Old Sep 18, 2004 | 01:03 PM
GurgenPB's Avatar
THer is no contradiction
10w30 was used initially, then to top it off later (about 1 qt), 15w50 was added. It says so in the comments. However, I would definitley not run 0w30 or 0w40; the latter has VII which is the root of many problems with turbos.
15w50 was an overkill.... I agree. Going back to 5w30 or 10w30.
Gurgen
derres
Aug 28, 2015 03:27 PM
EPG35
Aug 16, 2015 04:52 PM
wuppiedog
Aug 7, 2015 11:16 AM
ClwMike
Jul 23, 2015 12:55 PM
newbdriver01
Jul 15, 2015 06:10 PM
