Harsh 1st gear shift when cold
Old Apr 15, 2010 | 11:27 AM
eddystone's Avatar
Angry Harsh 1st gear shift when cold
I have a '07 G35x sedan, in the morning I would start the car and wait 10 minutes or so and go. I am starting to feel the car jerk when its shifting to 2nd gear I believe but is all fine 15 minutes later when the car is totally warm. Is this normal or is my transmission going to die?
From stop position I press on the gas to go and it jerks and wont happen again unless the car is stopped at a light or something but is all fine after 15 minutes of driving.
Old Apr 17, 2010 | 03:57 PM
Bauer418's Avatar
How many miles? You may just need a A/T fluid flush. No guarantees though.
I feel like a few other people have had this problem and they bought a new grounding kit (or made their own) and run new grounds from their engine, transmission, alternator and ECU. I guess sometimes the rough shifting was caused by a lack of necessary power and the grounding kit helped the current flow. Not saying it would solve your problem but I made my own grounding kit for $40 with some 1/0 gauge wire and ring terminals and it took only a couple of hours.
Old Apr 19, 2010 | 10:59 PM
eddystone's Avatar
Just got a transmission fluid change from Infiniti and its still doing it. What to do next?
Old Apr 19, 2010 | 11:07 PM
davidxu's Avatar
My 06 G35x does the same thing. When you didnt warm up the car enough from the cold, 1st to 2nd is really harsh. The whole car jerks forward.
I just let the temp needle start moving up before i put it into drive. Its all fine if i do that.
Old Apr 19, 2010 | 11:11 PM
eddystone's Avatar
I let it go to half way which is the highest it goes when the engine is fully warm and it still does it. What to do?
Old Apr 21, 2010 | 08:27 AM
eddystone's Avatar
I called up 2 Infiniti dealership in my area and none were familiar with a TCM reflash. What to do now since they don't know what I am talking about? will there be a difference between Canada and U.S. modules?
Old Apr 21, 2010 | 12:38 PM
Bauer418's Avatar
I doubt it's a TCM issue anyway since it wouldn't only be when it's cold. There may be a problem with the transmission in the G35x? Have you just brought the car back to the dealer and explained the issue to them?
Old Apr 21, 2010 | 03:45 PM
eddystone's Avatar
I bought it at a small dealership in the area (not Infiniti) and there's no way I can get a refund or even have them fix it for free. Its basically deal is done so everything is on me.
I don't think its a bad transmission because its totally fine when its warm, if it were bad then it would do it all the time. Has to do something with a temperture sensor or the fluid itself but I just got it changed by Infiniti.
Old Apr 21, 2010 | 08:23 PM
Bauer418's Avatar
Even at a small dealership, unless it was totaled, you still have factory warranty.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Learned Hand
Oct 1, 2015 09:02 AM
RWDguy4238
Sep 30, 2015 12:13 AM
Jcruzg35
Sep 26, 2015 04:47 PM
blnewt
Sep 25, 2015 01:48 PM
