Bad day ... IT happened... the engine blew...
Old Sep 19, 2004 | 09:19 PM
  #31
bullseye's Avatar
Re: Bad day ... IT happened... the engine blew...
Hmmm...
Pauter titanium rods: $795 each! Six of these would weigh as much as 4 of the chrome-moly rods...
Hmmm...
'03 G35s 5AT, Garnet Fire/Willow
Staggered 18" SSR GT1/Bridgestone PP S03
Eibach Springs/Sways, Stillen 2-pc BBK
Stillen Intake & SS Cat-Back Dual Exhaust
Old Sep 19, 2004 | 09:26 PM
  #32
gspot35's Avatar
Each! Wow....it must be cheaper to take out an insurance policy on your motor. I think I'll look into that.
Old Sep 19, 2004 | 09:29 PM
  #33
gspot35's Avatar
Looky
http://store.yahoo.com/ntnsracing/pabirovq.html
Old Sep 19, 2004 | 09:30 PM
  #34
malx's Avatar
What about a nice carb legal Stillen Stage II S/C with that lovely warrenty? [img]/w3timages/icons/smile.gif[/img]
Thanks - Joey Avino
Old Sep 19, 2004 | 09:43 PM
  #35
GurgenPB's Avatar
Spot,
The GB are unfortunately over, tey were held over a month ago.
The car had exactly 40,006 miles. Funny that it happened so close to such a round number... And yes, we were going through the twisties and I was running the car hard, albeit at a low-midrange boost setting. So it is entirely possible that once the rods heated up, they just gave way....
Gurgen
Old Sep 19, 2004 | 09:47 PM
  #36
GurgenPB's Avatar
Joe
Yes, I too have to do it rigt this time to have 0 problems (with the engine at least) in the future....
One question... you got custom made 100mm diameter sleeves made, or is it their overbore sleeves (but that's 4.2L)? Confused...
Also, they said that a stock, unsleeved block can do 650whp? Will sleeving help this or does this require decking the motor (in order to prevent the said problem)?
Gurgen
Old Sep 19, 2004 | 10:09 PM
  #37
350Now's Avatar
Hi Joe,
Glad to see your car is progressing along hopefully you will be back on the road soon. I am also worried about my rods and have not been pushing my car very hard. It's great to hear you went ahead and sleeved your block for an extra piece of mind. I think the 650whp for stock block is only an estimate. I would feel alot better knowing I have a sleeved and close deck block.
Gurgen,
You're plans for the re-build looks very solid. Can't wait to see what new monster lurks beneath that sedan of yours.
Regards,
Jeff
Special Thanks to: <font color=red>Rotora</font color=red>
<P ID="edit"><FONT class="small"><EM>Edited by 350Now on 09/19/04 07:11 PM.</EM></FONT></P>
Old Sep 19, 2004 | 11:50 PM
  #38
joenismo's Avatar
The AEBS sleeves can be bored out to 100mm because of their closed deck design. AEBS had a set of 100mm bore 8.5 to 1 custom made Ross pistons in stock. Sleeving the block will make the block virtually bulletproof as far as handling horsepower. The 4.2 liter AEBS motor is a combination of 100mm bore and a longer stroke crankshaft. The crankshaft requires even more machine work plus the cost of the crank itself. I am sure we will have enough power without any additional stroke. AEBS only makes one set of sleeves, but you can have them bored to the stock 95.5mm all the way up to 100mm. Basically the machine shop will bore the sleeves to the diameter of your new arias pistons. The sleeves costed about $850 and the machine work I think is going to cost around $1500. In my situation my rod broke at about 2000rpm not even in boost. It happened about 10 seconds after boosting through 2nd gear. I was able to turn the engine off right away. Yes it was still running. My block was repairable, had it fixed for $300, but that cylinder was going to need sleeving. This was another reason I went with the sleeves, it wasn't too much more for the sleeves + labor as opposed to buying a used engine or new block.
Old Sep 20, 2004 | 12:49 AM
  #39
Rob_G35's Avatar
In Search of Magic
WOW Gurgen sorry to hear this bro. This sucks but at least you are already gettin your new engine components. I hope everything works out man. Good Luck. I will call you tomorrow.
03 CB Coupe 6MT
Old Sep 20, 2004 | 01:13 AM
  #40
GurgenPB's Avatar
Thanks Rob....
Old Sep 20, 2004 | 01:21 AM
  #41
GurgenPB's Avatar
Joe...
Ok, I see now... So the sleves made by aebs are not like the Darton sleeves. This is a good option... I will be talking to AEBS really soon. I just heard that installing these sleeves is very difficult, and only good shops can do it. Is this true?
Gurgen
Old Sep 20, 2004 | 02:59 AM
  #42
Kamal34's Avatar
hey Gurgen, man im sorry to hear about your car. This may be a blessing in disguise. Now you really have a reason to build your motor and do watever mods you were thinking of doing. Good luck.
Old Sep 20, 2004 | 08:28 AM
  #43
TINMAN's Avatar
wow,i'm speechless....hope everything going well from now so you can be back on your feet soon.
steve.
Old Sep 20, 2004 | 09:12 AM
  #44
SoCalTed's Avatar
damn.
damn.
DAMN!
I am so sorry this happened to you Gurgen. It sure was fun while it lasted. Definitely a sanity check for everyone out there going FI.
In any case my friend, can you pull my plenum off your heap before you recycle it into a badass top fuel sedan. (oh sorry, did I let the Hello Kitty out of the bag?)
-T
p.s. my copilot's seat is open for you at any SoCal events.
'03.5 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS - www.teamtransport.org
Old Sep 20, 2004 | 11:38 AM
  #45
GurgenPB's Avatar
Ted
I sure will... I am sorry for not saying anything about it in this past month or two. There was of course no damage done to the plenu... When I build the motor, no parts will be lost, and will give you the planum back as soon as I take off the motor. I will be going with an upgrade to the plenum when I put it all back together.
Finally.... Now, di I really needed to blow my motor to get rid of the Hello Kitty! label?
G
