Updated pics of my headlights
Old Sep 20, 2004 | 09:18 AM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
I decided to give them a slightly different look. The amber turn signal, which I had as black previously, I now spray painted with "chrome" paint. The shield around the projector I wrapped with chrome cover.
You can see my old Legend in the background. Still running well even after 13 years.
Everything was resealed with OEM Nissan sealant. This is always such a pain in the butt ordeal (taking the headlights apart, etc).
Old Sep 20, 2004 | 11:15 AM
dyenboy's Avatar
Registered
Re: Updated pics of my headlights
tat looks clean..great job...how long did it take u too do tat..
GGG Member Signup
Old Sep 20, 2004 | 12:46 PM
JoeyG35's Avatar
What projectors did you put in the housing?
How do they perform compared to stock?
Old Sep 20, 2004 | 01:12 PM
E_K's Avatar
E_K
The projectors are BMW X5 projectors.
The original project took me about 20 hours last year, my thread on that is somewhere in the Coupe forum. This "revision," adding the chrome trim, etc, took about 12 hours total.
You may notice that I painted part of the headlight bezel. It's because some of the beam hits the bezel, and was causing glare, so I painted it flat black to reduce that.
The beam pattern is about the same strength as OEM in the foreground, but it's much wider, and the cutoff is sharp. I have pics of the beam pattern buried somewhere in this forum.
Old Sep 20, 2004 | 08:33 PM
Wicked_limitz's Avatar
man that looks Sick! how much did the projectors cost you? also did you paint your brembos? looks hott! i wanna do the headlights....let me know wassup? thanks!
04 IvoryPearl Coupe 6MT
Navi | Z-tube | ClearCorners | Alum. Pedals |
Soon 2 Come -Tein Flex
Old Sep 20, 2004 | 09:15 PM
kroams's Avatar
Someone needs to sell this as a kit ready to install.
2003 G35c/5AT/BS-Graphite/Prem/Aero/Splash/NISMO sway bars/JWT Popcharger/Z-Tube/ValentineOne
Old Sep 20, 2004 | 09:17 PM
accordfreak's Avatar
how about some pictures of it turned on? how did you make sure the lights were even and not facing too low or too high? looks good
RIP
1994 accord coupe ex
269whp / 281wtq @ 14psi
now....
a happy driver of a TB 6mt w/ navi
Old Sep 20, 2004 | 10:50 PM
E_K's Avatar
E_K
The up/down is adjusted with the stock assembly. Unfortunately, the X5 projector touches the dust cap, so I don't have as much lattitude as I would like to adjust. So the beam is a bit higher than I would like, but I'll solve this one day when the car gets lowered.
As for the Brembos, I bought those off ebay, they came red.
Old Sep 20, 2004 | 10:52 PM
E_K's Avatar
E_K
I am not good at taking night pics. If I use night mode, it's blurry unless I hold really steady, but in auto mode it doesn't represent the lights well.
Old Sep 20, 2004 | 10:53 PM
E_K's Avatar
E_K
This one came out better because I could rest the camera on the steering wheel.
Old Sep 21, 2004 | 12:12 AM
OOOOA3's Avatar
Alumni****
that looks insanely good.. i'm jealous =P
definitely a worth while mod..
David
04 Ivory Pearl G35C
Z-Tube/Popcharger, Fujitsubo Y-Pipe
Pioneer AVIC-N1
Old Sep 21, 2004 | 07:50 AM
kroams's Avatar
That really looks great. I still don't understand why Infiniti didn't give us projectors to begin with.
Old Sep 21, 2004 | 11:57 AM
that looks good! are you going to start doing more headlights and sell them?
Old Sep 21, 2004 | 12:37 PM
E_K's Avatar
E_K
I have offered a price in one of my previous posts, but this is not an easy job.
The projector retrofit was pretty easy on my Acura Legend. But with the G35 coupe headlights, there are a lot more space constraints/considerations.
If the projector is too far forward, you'll hit the clear outer plastic. Too low and your beam patter gets messed up by the bezel. Too high or too far back, and your HID bulb base starts hitting the dust cap. If you try and modify the dust cap by moving it, you might run into clearance problems with the fender liner.
On top of that, the bezel is very delicate. I had the passenger side develop one crack on me the first time I took it apart.
If I did another set, I would need a week with the headlights to do what I consider a good job (alignment, clearance, a good seal).
If you can do it yourself, the total cost for the job is less than $200.
Old Sep 21, 2004 | 03:28 PM
GUniiT's Avatar
i thought it would be more blueish/purplish looking..?
