Water pump question
Old Dec 14, 2010 | 03:36 AM
Tollboothwilley's Avatar
Originally Posted by the_coupe
here ya go. you can see the outlets from under the car if you point a light towards the back of the heads. i just did some on a 03 sedan today....took me about 4 hours to drop the motor, change the gaskets and put it all back together.
How did you determine this to be the issue - is is a visible leak dripping off the engine?
I've noticed my coolant levels going down about 1" in the reservoir every couple months it seems. I never see coolant on the ground or undertray though.
Old Dec 14, 2010 | 03:14 PM
AARONHL's Avatar
I found coolant all over the bottom of the car; spread over front sway bar and on the power steering rack. Level has been going down and I smell coolant inside the car with the heat on.
Haven't found a leak yet!!!!!!!!!
Old Dec 14, 2010 | 03:40 PM
AARONHL's Avatar
Doesn't look like I have a leak at the water outlet or water pump. The car has never overheated.
Old Dec 15, 2010 | 02:36 PM
HangUp n' Drive's Avatar
Could be your heater core, antifreeze will come out of your AC drain. Often you will see unusual window fogging issues as well.
Old Dec 15, 2010 | 09:50 PM
AARONHL's Avatar
Where is the drain??
Old Dec 16, 2010 | 12:33 AM
AARONHL's Avatar
No leaks from the heater core connections at the firewall.
Old Dec 16, 2010 | 09:02 PM
a heater core leak would normally cause very foggy windows that don't clean....they just smear from the coolant. Also, you can notice fluid under the floor mats sometimes. You would see coolant under the car after car is warm and it would be around where the engine/trans meet up at the bell housings most likely.
Old Dec 17, 2010 | 03:03 PM
AARONHL's Avatar
I haven't noticed my windshield being unusually foggy, my car doesn't overheat, and the heat is hot.
Old Dec 17, 2010 | 03:52 PM
AARONHL's Avatar
Had the car running on stands and still could not find the leak.
Kng0fHrts
Sep 15, 2015 05:40 PM
Smittie20
Aug 9, 2015 04:29 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
