Cam's anyone????
Old Sep 21, 2004 | 12:23 PM
zazaracing's Avatar
Team Transport Member
Cam's anyone????
Hey guys/gals does anyone have the upgraded cams in their coupes yet. I know only one guy do does but he has TT too so that doesnt help me im just wondering if its going to be worth the big bucks and which to go with.... thanks for your help.
03 6MT Coupe Blk/Blk> Injen CAI, Hotchkis adj Sway Bars, Test Pipes< "Nt G R8D" Aj
Old Sep 21, 2004 | 03:16 PM
Q45tech's Avatar
Re: Cam's anyone????
The 4 cams are cheap compared to dissassembly of engine to change them and new valve bucket lifters to achieve a precision lash and fit.
Might take 20 hours to do the job precisely!
Old Sep 21, 2004 | 06:55 PM
zazaracing's Avatar
oh ya i know the work is going to be a nightmare but gives me something to do instead of go out and party.
Q45tech I got a qus for you:
A few months back i crashed into a curbed pretty bad bent my wheel and i know i bet my lower control arm just a tad.
I got an alighnment and stuff its all straight now but I think my wheel bearing is bad too its just humming when i turn right if i turn left it goes away. I took ti to the dealer they said its the agressive tire tread because i have aftermarket wheels. do you think i should put my stocks on take i back to them or try another dealer or what..... your help would be great.
Old Sep 21, 2004 | 10:01 PM
booger's Avatar
ZZracing....I had that problem .Let me ask a question . Can you feel it in the steering wheel ? If so.....it may be the header on the drivers side . touching the steering collum .But dont know if you have headers or not .
Couldnt afford it when young...gonna play when Im old
Old Sep 22, 2004 | 02:23 PM
zazaracing's Avatar
No i dont have headers but ill check it ou more in that area thanks for the tip man.
Old Sep 22, 2004 | 07:24 PM
Q45tech's Avatar
Put it up on a rack and spin the tire and listen to the bearing with a probe stethoscope.
Old Sep 22, 2004 | 09:11 PM
zazaracing's Avatar
i spun the wheel with those bearing testers the machine looks like its from the 20's and i had another guy check it too both said its bearing the idiot in the suit and tie at the dealer said its my tire. I love when people with no knowledge of stuff work with CS
Old Sep 22, 2004 | 09:34 PM
WhiteG35C's Avatar
I have my Nismo R tune cams for sale since I got the Nismo spec 2 racing cams in now. Let me know if you are interested.
03 G35 Coupe: Check my profile for the spec./05 Subaru Impreza WRX STI
Old Sep 23, 2004 | 10:39 AM
tik1's Avatar
Getting back to zazaracing's question. Does anyone here have experience with the Nismo or JWT cams? I know one guy that does and I'm trying to get more information from him.
From what I've read (I think in Sports Compact Car) and heard the cams should provide some gain, but it is more noticable when other mods are added on like the plenum and headers.
6MT Coupe / Diamond Graphite / Graphite
Aero / Premium / Splash Guards / Trunk Mat
3M Clear Bra / Grounding Kit / Clear Corners / Aluminum Pedals
Old Sep 23, 2004 | 10:53 AM
winw's Avatar
White G35C, what's the difference between the type R and the ones you have? Are they direct bolt on, or does the engine need anymore modifications?
<img src="https://g35driver.com/rides/spec/pix/winw_1093819995.jpg">
Old Sep 23, 2004 | 11:50 AM
Q45tech's Avatar
As long as the engine is pretty new you probably don't have to measure and replace the 24 bucket lifters to get the valve lash correct. This can save 12 hours and tremendous extra work and reduce 25 hours down to 12.
Pulling valve covers, front covers and drive chains is the panful time consumming part along with their replacement.
Gotta have a young and good back to bend over for the duration. Almost easier to pull engine out and do the whole job on an engine stand.
Old Sep 23, 2004 | 04:05 PM
bzabodyn's Avatar
Crane should be coming out with a variety of camshaft sets that should be out in the first quarter of next year (perfect timing for me - I done with engine stuff for a while) - they will be VERY affordable compared to the other sets currently available (all $1,100+) at around $600/set and they will have various applications for N/A, F/I, and strickly race setups... they will definitely have my business when they're ready...
but if you are in the market for a set now, I would look into the JWT's - many 350Z owners have them and all have been giving them rave reviews...
2003.5 BS coupe 5AT
Clear Corners, Alum. Pedals, Pro-1 Intake, Resonated Test Pipes, UR Pulley, CF Engine Cover, GReddy EVO II, Kinetix Plenum, Hotchkis Sways, Pro-1 Headers
brianuc4
19
Apr 10, 2020 02:12 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
MThawkins86
Oct 24, 2015 02:07 AM
UT G35
Sep 3, 2015 03:58 PM
