Gordgee's Grounding Gear-Impressions
#31
Re: Gordgee's Grounding Gear-Impressions
I have a 5 wire kit, do you offer the additonal 7, 10 or 14 wire kits for G35 Coupe 5AT?
<font color=black>2003 G35 Coupe, Blk/Blk</font color=black>
<font color=red>Frisco, TX</font color=red>
TXREFI G35
TXREFI G35
#34
Gordgees Grounding Kits....?
Originally Posted by 4U2NV
where can i get these ground wire kit.. is there a website? with diff. prices. is there difference between these ground wires then the ones on ebay lets say
to PM him....and even order the kit. His merchandise if far superior to anything else on the market....
![Biggthumpup](https://g35driver.com/forums/images/smilies/biggthumpup.gif)
Gary
#35
upgrading wiring kit
I'm a 06 g35X owner and an electronics tech and am all about the grounds but all the kits i've seen don't solder anything, keeping it positive use the car audio amp cables (8 GA million strand wire) with plated 6 GA 5/16 hole ends and solder them, this allows you to run 1 continous length (without cutting the cable) under the hood. If you fold over 8 GA wire it fits perfectly in2 the 6GA plated end. I'm using a 175 Watt iron this will even work on 4 GA wire. Why because if you don't it will corrode and it makes a perfect connection that never has to 2 B replaced and will not degrade, (yes this requires soldereing skills) but is the way. I've done this on last 5 cars and swear by it. I'm not sure about DYNO stuff but blowing doors off almost everyone. Currenrly have 5 block points and 9 on body. Acceleration is OMG, use more points on the block. My grounds got all the wires under the hood, but the injectors ground is M66 behind the glove comp, have'nt got this one yet but will post pics soon. Not selling any product just informational.
No disrespect intended
