Cooling questions need some help plz!!
Old Jun 2, 2010 | 08:36 AM
Jiggy813's Avatar
OKay guys here is my situation. A couple weeks ago my 06 g35 coupe took a **** and the cooling sensor broke and overheated my car (While Parked). well i got the sensor fixed and it was working fine while doing speed limits. Well, since i have a g35 i hit the highway getting on it a little hard and the Temp Gauges Acted like my Speedometer Get the point? well im thinking to fix this problem im going to replace the radiator with a PWR radiator and a Nismo Thermostat. Can any of you guys think what else could be the problem.
I Appriciate all Feedback
Old Jun 2, 2010 | 12:02 PM
GTRDHybrid's Avatar
Before you replace the rad. etc. Try a coolant flush, and water wetter.. Unhook your rad completely and flush some 50/50 coolant fluids through that to make sure your free flowing with no clogs, as well. I know your not supposed to run tap water (distilled only) due to the irons and electrolysis that can occur from the crap in tap water.. I have my car on the poland spring/water wetter/15% coolant diet for the summer months here in PA, and it helps my temp by about 25 degrees alone..
Old Jun 2, 2010 | 01:13 PM
GTRDHybrid's Avatar
Also, while refilling your system, make sure you burp the air out correctly, you need to remove the bleeder cap, on the hose running into the heater box which is located near the batt. running into the firewall.. heres a good DIY I saw in another thread.
http://www.infinitihelp.com/diy/gsed..._procedure.htm
Old Jun 2, 2010 | 03:08 PM
DaveB's Avatar
Sounds like an air bubble trapped in the cooling system.
Old Jun 5, 2010 | 05:25 AM
darren1219's Avatar
i hope this isnt a bad question to ask, but how does an air bubble just get trapped in the engine all of a sudden and why is it so hard to flush out?
Old Jun 5, 2010 | 11:10 AM
Tollboothwilley's Avatar
Any time you open the system where air can be introduced into the lines you can have an air bubble get into the system.
Design of the engine and channeling of coolant is extensive and air can cause cavitation at the water pump or hot spots in parts of the engine.
Removing air is difficult because of the design. Easiest way to burp the system is to buy a funnel that locks onto the radiator fill and run the vehicle for 10 min.
Old Jun 9, 2010 | 05:41 AM
darren1219's Avatar
burping the system.
i studied the footage from the link and wasn't sure if that was burping the system.
after the person completed changing the coolant fluid and the washer and cap, I didn't see him turn the car on at all.
what is this running the car for 10 mins with the radiator cap off? I wasn't sure.
Thanks
Kng0fHrts
Sep 15, 2015 05:40 PM
ghost_g35
Aug 7, 2015 10:31 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
