Oil Catch Can...why?
Old Jun 8, 2010 | 10:08 AM
Matzo Ball's Avatar
Ok, somewhat of a noob question, but what are the benefits of an oil catch can? Merely asthetics or primarily for FI engines?
Personally, I was thinking of adding one for engine bay dress up.
Old Jun 8, 2010 | 10:23 AM
JOKER's Avatar
CLUB MODERATOR
Oil catch can designed to catch the oil out of Gulf of Mexico.
Old Jun 8, 2010 | 02:33 PM
Matzo Ball's Avatar
wow, amazing that is it so compact!
Now for a real answer.....anyone?
Old Jun 8, 2010 | 03:35 PM
GR6RR's Avatar
They need to design an oil catch can for the Gulf
Old Jun 8, 2010 | 03:50 PM
Swivel's Avatar
Moderator
Snip from nissanforums ( searched it up since I was curious, too):
"Catch cans fit between a port in an engine's valve cover and its intake and use the vacuum from an engine's intake to draw blow-by contaminants (oil, fuel, and exhaust gas that seep past the valve seals during combustion) out of the cylinder head and into a reservoir where they can be manually disposed of. In doing so, they also create low pressure within the head, allowing components to move more freely, decreasing parasitic loss. In many OEM applications, a simple vacuum hose is placed between the valve cover and the intake, which alleviates excess cylinder-head pressure and draws contaminates out of the cylinder head, but at the cost of re-circulating them throughout the intake tract; soiling intake manifolds, fuel injectors, valves, and decreasing intercooling performance of force-induced cars. Even more detrimental is when those cute little breather filters are used instead, that neither vent excess blow-by pressure as much as a vacuum-driven alternative, nor stint the build-up of contaminants in the cylinder head-doubly robbing power.
import tuner did this article and showed a dyno with a 3hp gain."
Hey, waitaminit, I think *I* might have one of those.
Old Jun 9, 2010 | 10:27 AM
Matzo Ball's Avatar
looks like these are really only for FI set ups. Really no benefit for near OEM NA, except for asthetics?
Old Jun 9, 2010 | 03:16 PM
jonnylaw's Avatar
^^Catch cans are not for aesthetics. They are functional. That's why you see lots of diy catch can setups.
Old Jun 10, 2010 | 06:33 AM
Blue Dream's Avatar
I drove ttrank's car solo
+1 on functional. You want to keep your engine as clean as possible and this will keep oil out of your plenums. I drain mine once a month and usually get 1-2 tablespoons of oil out of the can. Plus it looks pretty good in my bay!!
Old Jun 10, 2010 | 04:07 PM
Matzo Ball's Avatar
engine bay is looking good.
based on its current location, I would not be able to do that install since I run a Ztube/RevUp airbox. Front induction tube would be in the way. Where else can you locate it???
Old Jun 10, 2010 | 05:02 PM
Frankieg35's Avatar
Looks really good in that engine bay!!
Old Jun 10, 2010 | 05:06 PM
Swivel's Avatar
Moderator
Sure is!!!
Tim you ole pic *****
Old Jun 10, 2010 | 06:44 PM
Blue Dream's Avatar
Thanks Frankie!
Originally Posted by SwivelHips
Sure is!!!
Yeah I need to quit being such a ho but wanted to use the pic to illustrate my point.
Here is a perfect solution. Takes a little more work than my way but a lot of members have installed the can this way.
Originally Posted by OCG35
there's room... take out headlight, there is an existing hole that can be used - or drill new depending on where you want it positioned... you can use one bolt direct to can (even without bracket).
This can be done even when using OEM washer fluid filler neck and rad overflow tank
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
