Oil Change
Old Oct 4, 2004 | 10:31 PM
praztek's Avatar
Oil Change
Has anyone thought of cutting out the openings a little wider to access the pan/filter without taking the whole cover off? Just a thought.
Thanks
Old Oct 8, 2004 | 01:32 AM
accordfreak's Avatar
Re: Oil Change
i just take out two of the bolts..pull it down a bit and reach in...
RIP
1994 accord coupe ex
269whp / 281wtq @ 14psi
now:TB 6mt w/ nav
Old Oct 8, 2004 | 10:17 AM
jstwong's Avatar
Re: Oil Change
Actually, I did just that. I pulled down the under diffusers and then cut the opening a bit larger. However, when I did that, I had to cut away some of the metal stiffener strips. To me, this left things a little bit flimsy, so I then added back in new metal stiffener strips [from some spare flat stock aluminum], and pop riveted it in.
zoop425
Mar 29, 2016 05:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
