cams
Old Sep 19, 2010 | 11:57 PM
woRthy's Avatar
cams
looking to get a set of cams but cant find a g35 with a sound clip of a lobe of them cams, i want the biggest cam without have to upgrade springs etc... with a good sounding lope
Nissan
Stock 238/240 208/208 .375” 9.52mm
Nismo R-tune 262/262 .426” 10.82mm
Spec1 276/256 .433/.413” 11mm/10.5mm
Spec2 284/268 .433/.413” 11mm/10.5mm
JWT
S1 260/260 222.5/222.5 .428” 10.9mm
S2 256/256 219.5/219.5 .43” 10.92mm
C2 261/261 225/225 .456” 11.58mm
S7 (revup) 262.5/262.5 225.5/225.5 .45” 11.43mm
Brian Crower
Stage 2 264/264 222/222 .426” 10.82mm
Stage 3 272/272 234/234 .425” 10.8mm
Tomei
Stage 1 256/256 .401” 10.2mm
Stage 2 264/264 .401” 10.2mm
Stage 3 268/268 .413” 10.5mm
Procom Opt1 272/272 .413” 10.5mm
Procom Opt2 272/272 .444/.433” 11.3/11mm
Procom Opt3 280/280 .444/.433 11.3/11mm
Crawford
Street 265/265 .433/.433" 11mm/11mm
Race 292/265 .433/.433" 11mm/11mm
GTM
Turbo Spec 256/264 .423/.423" 10.744/10.744mm
Stage2 Turbo, 272/272 232/232 11.00/11.00m
Stage3 Turbo, 288/288 245/245 11.5/11.5mm
Stage 1 NA 264/256 .435/.423" 11.05/10.744mm
Stage2 NA, 282/272 240/232 11.50mm/11.00mm
Stage3 NA, 302/292 256/250 11.50mm/11.00mm
Scott's Performance (discontinued)
Stage 1 261/261 215/215 .403"/.403"
Stage 2 255/255 213/213 .410"/.410"
heres some things i found anyone got vid's or other builts?
Old Sep 20, 2010 | 01:42 AM
Shakuya88's Avatar
BC stage 3. Youtube "Alberto TT 350Z @ Idle"
Old Sep 20, 2010 | 02:08 AM
woRthy's Avatar
Wasn't lobeing :/
Old Sep 20, 2010 | 02:42 PM
HotRodG35's Avatar
If you run BC stg 3 cams it will require upgraded springs and pistons, also should change vallves. Hal @ Injected Performance could not guarantee the OEM valves wouldn't break with BC valve springs.
I run BC Stg 3 cams and do not notice much of a rough idle with solid motor mounts. RPM needs to be 900-1000
Its not safe to run stock pistons and valve train with cams > 268 duration or > 11.00mm lift.
I ran a ProStreet Dart with 310 duration and 575 lift, now that had a rough idle.
Old Sep 20, 2010 | 09:47 PM
woRthy's Avatar
So no chance of lobeing
Old Sep 20, 2010 | 11:17 PM
Tollboothwilley's Avatar
do you mean LOPING not "lobeing" ?
its not a V8, don't expect it to sound like one
Seems thats your choice of going for cams..
Old Sep 21, 2010 | 05:28 AM
HotRodG35's Avatar
If the idle is raised than no, like tollboothwilley said its not a V8.
brianuc4
19
Apr 10, 2020 02:12 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
MThawkins86
Oct 24, 2015 02:07 AM
UT G35
Sep 3, 2015 03:58 PM
