Kinetix Plenum
Re: Kinetix Plenum
you can hear more air rusing into the intake, but it's not really "loud" per se.
As for running lean, it means that by adding more air into the engine, the air / fuel ratio is effected. More air would be "lean", more fuel would be "rich"
An ECU upgrade from technosquare will allow you to adjust these things and accomodate for the "lean" conditions created by the new plenum.
My Team Transport Profile
Re: Kinetix Plenum
Actually to a point on a NA car, running "more lean" creates "more hp". Do a search on google for "lean rich stoichiometric" or "air fuel ratio AND stoichiometric AND gasoline" and you will have more info than you ever thought possible...
thechitoguy
Oct 1, 2015 05:25 PM
Julianpnce
Intake & Exhaust
Sep 1, 2015 07:41 PM
