View Poll Results: Which Spark Plugs?
Voters: 99. You may not vote on this poll
Can we get a 'once-and-for-all' answer on spark plugs?
#32
Typically for every 50hp to 75hp increase in power over stock, you should run a step colder plug, or if you live in a hot environment, or if you do a lot of racing with the motor in the rpm range. Here's a great write-up about spark plugs:
http://www.carcraft.com/techarticles...ips/index.html
NFSP G35 (06-06-2011)
#33
^ Thanks for the link
Should I run the One step colder plugs? Engine is nearly 100% OEM it has its timing advanced +2. I do live in south Florida were its hot most of the time.
But since my engine is stock I am looking at stock plugs heh.
Service Manual says
I drive 62 miles highway every time I go to school, which will be 4 times a week in Aug, But I dont know if that counts for extended.
And I redline it sometimes like everyone else
Service Manual says
Cold type spark plug is suitable when spark plug knock occurs with standard type spark plug under conditions
such as:
Extended highway driving
Frequent high engine revolution
such as:
#36
I use 1 step colder NGK copper. But between the 2 listed there, I'd use the Iridiums. Te platinum are just awful all around I feel. For DD cars, it's fine, but anyone who is modding a car in anyway should pull them out ASAP. platinum is not a good conductor and gets really hot, pre-ignition hot way too soon with any performance mods to the car. I had the platinum actually melt off the plug in 2 cylinders and get welded to the cylinder I think. (hope they are on the cylinder at least) just my $0.02
#37
#39
