blown engine:(
Old Oct 13, 2010 | 02:34 PM
2ffst4u's Avatar
Unhappy blown engine:(
I am a recently new owner of a fully loaded 2003 g35 6mt with 67000 miles on it! Unfortunatly I blew my motor driving from north carolina to yuma arizona and it happened in georgia. My water pump went out and some weirdo guy offered to replace it and as I was on a time crunch to make it to my duty station in time I agred and took off the next day and same thing happen in the exact same spot on the freeway I want to rebuild it I also want to bore it out as I am already going to be tearing it down but I want a package deal where I can buy almost everything together....any suggestions?
Old Oct 13, 2010 | 02:49 PM
lowso's Avatar
dang sorry to hear that.. gl though
Old Oct 13, 2010 | 02:56 PM
NMG-4's Avatar
do you know the reason why the pump broke?
Old Oct 13, 2010 | 03:32 PM
2ffst4u's Avatar
I have no clue it broke twice though and I started hearing a noise a little bit after I got it and I took to some people and there like oh its normal or oh its one of the pulleys bearings going out so I was like **** and outta no where it stopped and I fogot about it and started my drive and sure enough it went out but now the whole bottom end is blown and has horrible acceleration and lots of noise I just wanna do a mild build on it a little more than stock so eventually I run FI but I'm going for the recommended compression rather then FI compression I have access to any tool lift shop but it would be cheaper for me to do it rather a shop so I'm clueless as of now lol
Old Oct 13, 2010 | 03:55 PM
vp-g's Avatar
ls2 is your friend.... you will be happy you did
Old Oct 13, 2010 | 04:05 PM
2ffst4u's Avatar
Ls2......major modification right? My father has a 2000 vette with the ls1 but wouldn't that take a lot of fabrication of moving mounts and sure it would fit?
Old Oct 13, 2010 | 05:11 PM
vp-g's Avatar
https://g35driver.com/forums/forced-...rbo-build.html
Old Oct 13, 2010 | 05:17 PM
2ffst4u's Avatar
Ok so engine tranny? Drive train? Right
Old Oct 13, 2010 | 05:25 PM
vp-g's Avatar
and ecu....yep it can be done as long as you have the funds.
Old Oct 13, 2010 | 05:27 PM
suprasam's Avatar
are you still in georgia? did your car go down anywhere near marietta?
Old Oct 13, 2010 | 06:27 PM
2ffst4u's Avatar
No I paid for a uhaul and trailor and hauled it to yuma arizona it went down in augusta
seagrasser
May 3, 2022 09:43 AM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
Eomfd
Aug 29, 2015 12:42 AM
