pulling cam sensor from plug
Old Oct 15, 2010 | 10:00 PM
V'sG's Avatar
yo fellas i cant get the damn plug off the sensor. i took off the sensor from the block first with the plug still attached. i cant seem to separate the two. any ideas? thx
Old Oct 15, 2010 | 10:45 PM
Shakuya88's Avatar
Push in clip...pull? Maybe try pushing in the clip and taking a flat head and GENTLY twisting between the sensor and plug.
Old Oct 15, 2010 | 11:08 PM
GHOS7's Avatar
I can't stress enough about being gentile with harnesses and sensors. They go through lots of vibration and can break easily.
Shakuya88 is right, try to push it in and then try to rock it out. If you have a very thin flathead... try to push it into the sides of the connector so that you can break both surfaces free wherever it may be stuck. :/
GL
Old Oct 16, 2010 | 02:33 AM
V'sG's Avatar
GL
thanks a lot bro. just having a hard time w it.
Old Oct 16, 2010 | 05:42 PM
Shakuya88's Avatar
Another thing that may help, is put the sensor back in and attach bolt and try to disconnect sensor then. I have not done this before so I'm not sure how much room there is and if this is possible, but the extra (leverage...while being gentle) could make the difference.
mtlruss
Dec 20, 2015 01:51 PM
Dat Kid
Nov 23, 2015 11:18 AM
cmesidewayz
Sep 29, 2015 09:28 PM
flytim3
Sep 5, 2015 01:23 PM
Ken167
Aug 7, 2015 11:12 AM
