DIY VQ35HR/VQ37VHR thermostat replacement on VQ35DE
Old Nov 6, 2010 | 03:40 PM
Andrei's Avatar
The coolant caps I am using to bypass coolant are finally starting to show their age... about 4 months. It's no longer safe to run the car with them for much longer so I started today with replacing the thermostat.
Procedure took less than 15min total. I didn't even have to bleed the air out. Just topped it off and used my left hand palm to push on the radiator inlet and squeeze the bottom radiator hose and that pushed the air bubbles out into the overflow tank.
Old Nov 6, 2010 | 11:08 PM
jamese85's Avatar
Is there lower temp thermostats available as well? I need to do this soon, so thank you!
Old Nov 6, 2010 | 11:30 PM
Andrei's Avatar
Nismo makes one but it doesn't make a difference in bringing temps down. All it does is open at a lower temp so it opens sooner.
Old Nov 30, 2011 | 11:58 AM
P10 WRC's Avatar
so this t-stat is used for when you remove the oil cooler lines correct?
Old Dec 6, 2011 | 12:14 AM
SxExCx's Avatar
Correct, the HR t-stat does not have the fitting for the DE oil warmer, thus bypassing it.
Old Dec 29, 2011 | 05:55 PM
Deepdiver's Avatar
i dunno about you guys, installing that upper right bolt is a PITA
tiguy99
Mar 1, 2016 11:42 AM
yassy
Aug 9, 2015 07:31 PM
Smittie20
Aug 9, 2015 04:29 PM
Jussaku
Aug 4, 2015 12:45 PM
newg37
Jul 26, 2015 09:32 AM
