single gauge pod a-pillar
I have a defi boost gauge that I want to run with my vortech setup on my 06 coupe and was wondering if anyone knew of a single guage pod for the a-pillar. The only ones I can find are the dual and tripple, but I only want to run the one gauge. I know they make one for the 350z in single but assume that wont fit the g35. If there isnt one what is a good solution as I would like the gauge visable to the driver ( not in glove box ) and I dont what to have something custom made and spend alot of money. Can anyone help?
i'm almost positive i saw one when i was figuring out what to do with my gauges. i'll take a look around online to see if i can find it again.
you can also go with the single gauge holders that you can mount anywhere. they are small, mostly wire, and can sit right on top of the steering column between the tach & speedometer.
Couldn't find one that was G specific, but here is one for a Z. I wonder how different in size our pillars are?
http://yhst-16298468643776.stores.ya...52sigapo1.html
Edit: cheaper here: http://www.jscspeed.com/catalog/Auto...0Z-3816-1.html
Thanks for the help guys! That would be great Bigc if you could track down where you saw that. That is ultimately what I'm looking for. Anyone know if the one for the z would be a close enough fit?
i looked back at the sites i purchased from. i found that the single pod i saw was indeed for the 350z (autometer 20809). anyway, the prices on google shopping are pretty cheap, so for $20 it may be worth the risk of trying it out.
^ that's a good point. OP, what type of gauge are you going to install? If you just want one, consider a multigauge like the ones sold by PLX. I'm running two in a dual guage pod, with AFR, oil temp, tranny temp, and coolant temp on one, and boost, vacuum, oil pressure, and RPM on the other.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Learned Hand
Oct 1, 2015 09:02 AM
