Electric fan install help
Eric or anyone
Know where wiring diagram for factory harness showing all eight wires for cooling fans?
I have
Blue
yellow
black
white
on one harness and
black
red
black/white
yellow/red on the other.
Trying to figure out how to wire relays to handle 14' spal fans.
I have cross referenced multiple threads on driver and my350z but none seem to tell me which ones can be used to trigger relay and which are tied into ignition.
I'm obviously not an electrical wiz, to say the least.
Thanks,
George
I have
Blue
yellow
black
white
on one harness and
black
red
black/white
Thanks,
George
Truth is our systems run off a can-bus system and the signal is either postive or positve
so with that said you'll run into some headaches which is why I had to do a full standalone setup for the fans.
I'm up in West Palm Beach, around how much would it cost to delete the mechanical fan go two electrical fans?
broke_as_ajoke
Aug 22, 2015 08:27 PM
