Mode 6 testing
Mode 6 testing
Does anyone have access to a chart that shows what each particular Mode 6 test is referring to?
On a Snap-on Modis, you car run about 30 tests ( each one pass/fail) but it does not show what device each test is testing.
I have been trying to figure out a no-start issue. My car was running fine. Parked it for 15 minutes, then would not re-start. It was cranking and almoast starting but would not stay running. Just about to call a tow truck, and gave it another try, and it started and ran fine. No CEL; No DTCs, no pending codes, no freeze-frame data. Everything OK. Ran all the Mode 6 tests, and all passed except No. 1. Car is still running fine, but I'd like to find the problem before I get stranded.
Aside from this one Mode 6 code, I'm thinking maybe the car needs a crankshart position sensor....but I'm just guessing.
BTW car has 125k miles; 25k on motor, (but all sensors, harness, injectors are from old engine), A few injectors and most coil packs have been replaced over the last year or so.
Visionnn
Oct 3, 2015 05:16 AM
master111
Sep 25, 2015 08:32 PM
