Choppy Idle
Old Nov 30, 2010 | 04:49 PM
4DoorGRider's Avatar
RS Motors Tuned
Exclamation Choppy Idle
What's up everyone. Have a quick question. I had my car parked outside for around 9-10 hours while at work. It's rather cold outside, around 21 degrees, with a cold wind chill. I went to start the car up, the motor hesitated for a few seconds, and felt like the car had a weak battery. Once it started (around 3-4 seconds) the car had a very rough/choppy idle. The rough idle lasted a few minutes. There was also a rotten egg smell around the car. I noticed the car vibrating while the car was running, probably because of the motor. However, once I drove the car around the parking lot a few times, the motor ran fine. Started up just fine, and ran like normal. Anyone know what could have caused the initial rough/choppy idle? Thanks for the help. Would also like to add the car never threw a CEL light.
Old Nov 30, 2010 | 05:22 PM
G35xChicago's Avatar
Maybe just the temp conditions? did this happen on more than one occasion? Sometimes the oil needs time to warm up and thin before you drive which can cause choppiness
Old Nov 30, 2010 | 05:27 PM
RS Motors Tuned
This is the first time I've had this happen. I'm running Castrol Syntec 5W-30 oil. Never had an issue before. Maybe bad batch of gas?
Old Nov 30, 2010 | 09:22 PM
| 1cleanG |'s Avatar
almost sounds like condensation in you're fuel
Old Dec 3, 2010 | 05:15 PM
RS Motors Tuned
Update in case anyone wanted to know. Car had a misfire in cylinder #1. Turns out the HKS Ignition Amplifer I had on caused the problem.
Old Dec 9, 2010 | 04:15 PM
SedanFan's Avatar
I had the same thing happen to me about a month ago. I had the car up on the jack stands on an inclined driveway working on the front brakes. After I lowered the car the idle was really choppy so I turned the engine off. Then It wouldn't start. So I jumped it and forced it. It ran choppy, stunk and now runs perfect like nothing ever happened. I don't have the HKS Ignition Amplifier so I have no idea why it happend to me. Huh?
Thebaws11
Jul 2, 2021 11:36 AM
Vqalexisz
Oct 14, 2015 12:48 AM
vamarris
Sep 26, 2015 12:56 PM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
Jnm07
Sep 5, 2015 01:16 AM
