Please help! power steering question
Old Dec 7, 2010 | 07:08 PM
madnaz's Avatar
Hi guys, I have a 2003 G35 coupe with roughly 82000 miles on it. Last night I was driving along and all of a sudden my power steering went out. My service engine light, vdc off, and slip icons lit up in the dash. I stopped in a parking lot and killed the engine. I went to crank the car, and it stuttered a little bit before actually cranking. I figured that it might be low fluid, but I thought I'd ask you guys what you think. Thanks in advance.
Old Dec 7, 2010 | 08:49 PM
the_sedan's Avatar
get the codes scanned. if the fluid is low, check for any leaks. my guess is maybe the p/s pressure switch went bad.....if so, there should be a code for it.
Old Dec 12, 2010 | 01:48 AM
Shakuya88's Avatar
If it is the P/S pressure switch, it's P0550 and a generic scanner won't pull it up and it also won't set the SES. Mine had been unhooked on me and the light never came on, on realized 'cause it was harder turning at idle. Cipher came up with the code.
Old Dec 12, 2010 | 12:56 PM
DaveB's Avatar
Did you check the belts?
Old Dec 14, 2010 | 02:34 PM
madnaz's Avatar
Thanks guys, I popped the hood and my belts looked pretty worn. I'm gonna get that taken care of asap
mann1961
Aug 9, 2015 08:44 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
