overheating
Old Jan 4, 2011 | 07:43 PM
fstasfk_G's Avatar
overheating
my car tends to over heat while sittin still, but fine when driving, i guess the wind helps it cool down....
does anyone know how to check to see if its the fan or the sensor?
finally, does anyone know how much it would cost to get it fixed?
Old Jan 5, 2011 | 10:42 AM
brandon1978's Avatar
On your 2004, I think you should have two electric fans. Even if the engine is cold, if you start the car and turn on the AC, both fans should immediately come on. Do they? If so, are they blowing hard enough? Is the coolant in the radiator full and in the overflow reservoir between min and max? If so, when was the last time the coolant was changed?
Old Jan 5, 2011 | 07:43 PM
Tollboothwilley's Avatar
AC fans should engage withing 30 sec of turning the AC on.
I'm willing to bet your fans are bad. Perfect scenario of fans going out that you just described.
Let your car idle. If the needle moves at all then pop your hood. both fans should be fully engaged on high speed. If not - your fan(s) are bad.
Old Jan 10, 2011 | 08:46 PM
byte_me77's Avatar
fan warranty was extended by nissan, so go to your dealer and they might replace them for free.
Old Jun 11, 2011 | 04:14 AM
acee's Avatar
Addict
hes right i just got mined placed free at the dealership check with yours.
Old Jun 11, 2011 | 10:27 AM
i believe the fan warranty extension is limited to the 2006 models only though. Has anybody had a free replacement with a 2003-2005?
G35Rican
Jul 31, 2024 01:37 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Jay123
Sep 28, 2015 08:42 PM
yassy
Aug 3, 2015 12:24 AM
joedaddy1
Jul 28, 2015 02:58 PM
