p0132 & p0152 codes, rough idle when cold
Old Jan 19, 2011 | 07:56 PM
Row2k's Avatar
20 Year Member
G35 Coupe
Hi everybody,
These two codes popped up just yesterday for what seems to be no apparent reason:
p0132 - O2 Oxygen Sensor Circuit High Voltage (Bank1, Sensor1)
p0152 - O2 Oxygen Sensor Circuit High Voltage (Bank2, Sensor1)
I have ART test pipes, but my car is an 03 and I have had zero issues with them throwing codes. Also what are the odds of both O2 sensors going out at the same time?
I did get gas at a different gas station than usual and the car does also seem to idle rougher when cold, but even when switching back to my usual gas station and filling up...still the same code, so what gives gents? Any suggesions as to the cause ?
Old May 31, 2011 | 08:37 PM
matdaddy's Avatar
I got the same issue brother ... Did you fix it?
Old May 31, 2011 | 08:40 PM
infinitig35's Avatar
I would like to know also. Thanks.
Old May 31, 2011 | 09:45 PM
Row2k's Avatar
20 Year Member
G35 Coupe
not really sure why but the issue went away on its own I also got a tune and the car's been running better than ever since
Old May 31, 2011 | 10:13 PM
matdaddy's Avatar
How long did it take to resolve? Did u get a tune with consult?? I got fast intension cats , z tube stillen filter and plenum spacer and I keep getting these dam codes
Old May 31, 2011 | 10:20 PM
Row2k's Avatar
20 Year Member
G35 Coupe
maybe a month after first popping up. I got an uprev tune about 2 weeks after it went away and I have ART pipes, plenum spacer, z tube, and an invidia true dual.
Old Jun 1, 2011 | 05:25 PM
matdaddy's Avatar
So uprev tune should fix my issues and clear the codes? My cars seriously running like a bag and has sudden jumps in power.. Can the dealer do soemthing with the consult?
Freeman186
Sep 6, 2023 10:07 AM
Vqalexisz
Oct 14, 2015 12:48 AM
Jnm07
Sep 5, 2015 01:16 AM
n2fooz
Sep 4, 2015 07:46 PM
