Idle and Stalling problems after mrev installation
Old Feb 21, 2011 | 08:33 AM
specv5150's Avatar
I recently purchased a Crawford plenum and mrev2 and began installaytion a few days ago. Two of the throttle body screws were stripped, so I took the whole upper plenum off with throttle body attahced (i.e. unplugged it....I guess mistake one). I still couldnt get the screws off so I said forget it.
Yesterday I went to install just the mrev 2. Installed just fine. Actually was pretty easy. I had a little problem with getting the holes all lined up on the upper plenum but I eventually got it. I put everything back together and did the relearn steps listed here http://www.technosquareinc.com/350reset.htm. I did this since I unplugged the throttle body.
Started it up and got a ridiculous idle and stalling. I rechecked all my work (i.e. removed upper plenum Leaving throttle body connected this time), checked vacuum lines, etc.
Did the relearn again.
Same thing.
When I first start the car the idle jumps to like 5K (almost like I was intentionally revving it..which I wasnt).
Then it drops down to about 1K, feels shaky and the drops even more to around 200. It will almost stall (battery light comes on), then catch, then eventually stall.
I havent tried driving because I dont want to get stuck somewhere (would that even help)?
Did I miss something?
Old Feb 21, 2011 | 11:55 AM
banelba's Avatar
Sorry for the trouble, wish I could help but it's hard without being by the car. After putting a spacer on mine, it will idle high before going back to normal. Let it run for a while to see what it will do. Good luck
Old Feb 21, 2011 | 12:11 PM
SxExCx's Avatar
Make sure the rubber ring around the oil fill neck isnt pinched between the upper and lower plenum.
Old Feb 21, 2011 | 12:41 PM
specv5150's Avatar
Check.
I literallly triple checked everything. No loose vacuums. Everything is tightened down. All electrical connections are secure.
I think I am just going to take it to Nissan. Just sucks because the closest Infiniti is like 90 miles away AND whatever it cost is going to be nearly double since I am in England and have to pay in pounds
Old Feb 21, 2011 | 02:34 PM
sTeadFasT96's Avatar
My guess is there's definitely a vacuum leak somewhere. I know you have mentioned that you have checked everything, but as far as I know, if the engine doesn't hold it's idle that means there's a vacuum leak SOMEWHERE.
Old Feb 21, 2011 | 03:47 PM
specv5150's Avatar
Ill quadruple check tomorrow. See what happens...cant hurt
Old Feb 21, 2011 | 05:23 PM
I know when I installed my spacer I just forgot one of the vacuum lines and did what you are describing except it didn't jump to 5,000rpms as far as I can recall. But it'd drop and catch for a sec, sound really crappy, and then die.
Old Feb 21, 2011 | 07:02 PM
DaveB's Avatar
It would be a lot cheaper to remove everything and reinstall it again. I'm certain you've got a signficant vacuum leak somewhere.
Old Feb 21, 2011 | 09:43 PM
Tollboothwilley's Avatar
vacuum leak
something isn't connected. Like Dave said - remove it all and reinstall. You'll find something wrong along the way. I'm sure of it.
Old Mar 12, 2011 | 10:49 AM
specv5150's Avatar
UPDATE:
Installed Crawford upper plenum. I think I missed a bolt or two in the back during install so that might have been my stalling issue. Now it doesnt stall, but I have a rough idle. It will almost stall, then catch and go back to around 1K. Car feels rough too....
I did the relearn procedures....maybe I am just not doing it properly?
Old Mar 12, 2011 | 12:52 PM
superchargedg's Avatar
Did you use any carb cleaner spray cause that can help pinpoint the vac leak location.
Old Mar 27, 2011 | 12:22 PM
specv5150's Avatar
UPDATE for anyone who might search and have the same problem.
The gasket between the crawford plenum and the mrev wasnt seated properly. I had a really rough idle but no stalling. After a few days I also had what I would say was a whistling sound. Sounded awful. I ordered another gasket, but I am in the UK so it takes awhile (unless I want to get raped with UK prices...I paid $25 on ebay. With the conversion rate and UK pricing, that same gasket would have been $165). In the meantime I used some RTV inconjunction with my old gasket and it works for now.
Old Mar 28, 2011 | 03:18 AM
MM_G3520's Avatar
Yeah, your original symptoms sound exactly like a vacuum leak. I hope it all works out. How did you bolt down the upper plenum/lower plenum? Did you use the criss-cross type pattern (per Motordyne instructions), or did you just tighten your way from one end to the other? Did you tighten to the necessary inch-lbs spec?
Maybe you should try dipping the gasket in oil and reinstalling it. It'll help create a good seal.
Old Mar 30, 2011 | 03:11 PM
specv5150's Avatar
I followed the instructions and used the criss cross pattern. I just think it was the gasket. Mine doesnt lay flat anymore. and it would constantly move when I was trying to line up the upper plenum to tighten it down. I could hear a whistling sound coming from the plenum in the exact location my gasket is "bent" (for lack of a better word) when I did get it on. So the RTV and my crap gasket are okay for now. I will do it all AGAIN when my new gasket gets here.
In the meantime I must say the sound is amazing!!! I can definitely feel a difference with the mrev and plenum combo when driving too. Well worth the money and headache
chinee
Jun 10, 2024 07:48 PM
jsimonk
Dec 22, 2023 03:49 PM
Muski_G
Dec 1, 2023 11:11 AM
Terry_G35
Aug 4, 2015 02:38 PM
sick_sixspeed
Tuner & Dyno
Jul 21, 2015 03:23 AM
