warning lights on dash
Old Nov 10, 2004 | 04:10 PM
BEK27's Avatar
while running around "the track" yesterday my brake, slip and VDC off lights all came on. I thought it might have been the heat, but they still haven't gone off after sitting all night.
I have an appointment set for Friday but was looking for some help?
Old Nov 11, 2004 | 02:36 PM
Msedanman's Avatar
O.F. Administrator
Re: warning lights on dash
There is a recall/TSB on a brake switch malfunction you might look into. The recalls and TSB's are in our DIY/FAQ forum.
Low brake fluid level will cause a warning light, as well as worn out brake pads.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Nov 11, 2004 | 05:20 PM
ChicagoX's Avatar
Don't drink and Mag Race
I got the same warning when I accidently started the car without the MAF hooked up. All of the lights save the SES light went off when the MAF was reconnected.
Someone also experienced this after some "excessive" burnouts.
Was your MAF unhooked for any reason?
Did you pull any fuses?
Good luck!
'04 G35X Graphite/graphite, NAV, wood, premium
"May you lead an interesting life..." -- Old Gypsy Curse
Old Nov 13, 2004 | 11:57 AM
BEK27's Avatar
Thanks,
I was low on brake fluid and they replaced the front brakes and rotors. I love the Infiniti warranty!!!
Tires are to expensive so I try not to spin them. When they said it was free I didn't ask any more questions. I was headed for the door.
deschutes606
Jul 18, 2018 09:34 PM
wonderizm
Sep 24, 2015 03:09 AM
mjfenix
Jul 17, 2015 02:07 PM
