Replacing the spark plug well seals in the valve covers
Old May 9, 2011 | 01:06 PM
onthe3rdday's Avatar
The above picture was my reasoning for tackling this job. As you can see in the post, my spark plug electrode is worn down and the plug is bathed in oil. I had this problem on my rear passenger side plug and on my front-most driver side plug. There are two ways to solve this problem. Replace the seals with the kit from R&D Factory or replace the valve covers with new ones. The new covers are about $180 each. I chose the R&D route. R&D kit offers the kit with the following pricing structure.
60 for 6 orings
90 including oem valve cover gaskets(both side)
100 including oem pcv valve and the gasket.
The Installation is extremely straightforward and I followed the DIY from R&D Factory.
It's necessary to print the intake manifold collector and rocker cover section from the factory service manual in the Engine Mechanical section. These sections give you torque values and bolt removal and re installation order. I also used the instructions on this G35DRIVER thread to Reset my ECU, and reset my idle (I removed and cleaned my throttle body). Swivel sockets help, torque wrenches for inch-lbs and foot-lbs are absolutely necessary. Also needed is a hole saw size 1-7/8 which I got from my local ACE Hardware in Bridgeport, CT and black RTV silicone which you can get anywhere. Set aside 4 hours if this is your first time.
Remove the manifolds and covers.
You must drill concentric holes are the plug tubes. Notice my middle one isn't. Don't do that!
You can then put rtv on the underside of the new seals and the pop right into position.
If you remove your throttle body and unplug it to clean it, your ecu will hate you and your warm idle will sit @ 1150. I resolved the problem by letting the car cool down, then I did ECU reset, accelerator Pedal realease position procedure, then Throttle valve closed position and lastly I warmed up the car to do Idle Air volume learning. Some other pics from the job are below!
If you have never used a hole saw before, practice on something first!
Old May 10, 2011 | 09:34 PM
Texasscout's Avatar
I'm a little lost here. Why did you need a hole saw? What were the "O" rings? Just plain O-rings or were they square profile seals that are round like an o-ring?
Old May 10, 2011 | 10:07 PM
I needed a hole saw because the valve covers are plastic and the spark plug tube seals are inaccessible. You have to drill out the plastic around the seals to pull it out. With the kit from R&D Factory the o-rings are round and the "pop" into position just like traditional spark plug seals
Old May 14, 2011 | 08:31 PM
Texasscout's Avatar
I asked about the oring because of the prices you posted. $60 of SIX ORINGS? That's nutz. Even if they were Viton (tm) (up to 400 degF), the cost of the rings is only pennies each. If they are of a common size (even metric), not proprietary, you can buy them at most any "Seal and Gasket" shop for less than a dollar each. You would just need to size them. The only elastomer that would be more expencive would be Aflas (tm) or Kalrez (tm). Both of those will handle up to 500 degrees.
All those elastomers and many other were invented by DuPont.
Old May 14, 2011 | 11:59 PM
Agreed that 60 bucks for o-rings is like paying $60 for shoe laces, however, I am not knowledgeable enough on the subject to find the product I needed. Kudos to r&d factory! At the end of the day, replacing o-rings in valve covers designed like ours is time consuming. A more traditional metal cover with shelf stock o-rings would be ideal.
Old May 15, 2011 | 11:16 PM
datbeans's Avatar
onthe3rdday, i know you only posted this 6 days ago but maybe on you next oil change can you give us an update on how the new seal are holding up?
Old May 16, 2011 | 01:00 AM
Sure will, I got 1K miles on the car since that job
Old May 22, 2011 | 07:41 PM
AlanM's Avatar
I just did my driver's side yesterday. still have to do the pass side. didn't want to put it back together half done but its my only drivable car, currently, and I had plans for the evening.
Anyway, anyone who is interested in tackling this, I made a bushing to center the hole saw over the plug holes...it worked great!! pm me if you happen to be interested in this.
Old May 22, 2011 | 08:42 PM
A bushing to center the hole....nice! Taking off the manifold to do this twice= you are a beast. Admittedly I had to take mine down twice, but rfor another reason.
Old May 22, 2011 | 09:28 PM
AlanM's Avatar
lol. taking off the manifold is the easy part. looks like getting the pass side valve cover off is gonna be a pain! I had thought maybe I could do some port work to the manifold while I had it off but, it doesn't look like there's much to be done in there! It all looks pretty good (aside from needing a good cleaning).
Old May 22, 2011 | 11:26 PM
Passenger side is a BITCH. No if's and or buts about it. Enjoy! Something tells me you'll be fine.
Old Jun 5, 2011 | 08:07 PM
AlanM's Avatar
its all done. has been for about two weeks now. so far, so good. the pass side wasn't as bad as I thought it might be.
Old Jun 7, 2011 | 08:26 PM
Jmurray89's Avatar
onthe3rd,
Just ordered my seals, 5th spark plug tube is leaking. I figured I would do this fix since I am putting the mrev2 in. How is everything holding up so far since you did this?
Old Jun 7, 2011 | 08:37 PM
AlanM's Avatar
its holding up good as far as I can tell, so far. If you want a bushing to center your hole saw, let me know. It made the job way easier than it would have been without it!! Also, the baffles didn't come out of my valve covers by keeping the hole saw so well centered. You just have to be more clean this way...keep the plastic shaving from getting under (over) the baffle.
-Alan
Old Jun 7, 2011 | 09:44 PM
Jmurray89's Avatar
Not sure if I completely understand. Aren't the baffles molded to the valve covers anyways, preventing them from coming out?
How did you keep the shavings from getting behind the baffle? And is your way messier than without the bushing?
All in all, I would want a bushing to center the saw to make the job easier.
