Will a 350Z engine bolt directly into a G35 Coupe
Old Nov 21, 2004 | 01:14 AM
SKYL1NE's Avatar
Can anyone tell me if a 350Z engine is a direct swap with a G35 Coupe.
Thanks,
AlanL
Old Nov 21, 2004 | 09:39 AM
roneski's Avatar
Devil's Advocate
Re: Will a 350Z engine bolt directly into a G35 Coupe
I don't know that anyone has tried it, but it should be. It's the same engine in the same configuration.
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-- Abraham Lincoln
Old Nov 21, 2004 | 03:13 PM
Msedanman's Avatar
O.F. Administrator
I think you'd need the ECU/TCU along with the engine tho.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Nov 22, 2004 | 10:11 PM
KPierson's Avatar
I think you would be better off with the G35 ECU and TCU. They should have the exact same BCM/ECU/TCU but with differnet programming on each. This is just a guess, and I may be wrong, but the cars are so similar I would imagine the engines should just swap right in.
Kevin
www.KPtechnologies.net
AIM: KPiersonTec
04 DG Coupe / VDC Memory
OEM Remote Window up mod
Procharged / Crawford / TS
Old Dec 4, 2004 | 04:28 PM
ZeroGen's Avatar
Omega Enthusiast
I don't see why it wouldn't considering it's the same exact engine but with different tuning.
Old Dec 4, 2004 | 04:37 PM
KPierson's Avatar
One important thing to keep in mind is that Nissan discontinued the RB series of motors because it was only used in the Skyline. This wasn't cost effective and so they switched to using the VQ in almost everything. In order to keep the VQ cost effective they will have to keep it as similar as possible from car to car. So, my guess would be different software tuning on the ECU and differnt air intake systems. The block, engine internals, trannys, and other important, expensive things would remain the same. The intake would be easy to modify because they are all plastic!
Karnicle
Jul 23, 2015 05:08 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
