Need help asap :(
Old Jun 25, 2011 | 03:16 PM
jon121587@yahoo's Avatar
Need help asap :(
Ok today my CEL came on. Took it to autozone to get it Read. Turned out to be Code PO442 (smal EVAP leak). Guy at auto zone said it was more n likely the gas cap and said to clean it off because might be dirty so I cleaned it up tighten it 3 clicks. I reset my ECU using the pedal method. Turn the G on and then CEL is Blinks for a bit then goes away and comes back blinking WTF NOw!!!! I said to my self. Any suggestions cause I'm freak out Now Is this a serious prob????? Oh yea the G idles fine if that matters
Old Jun 25, 2011 | 06:23 PM
superchargedg's Avatar
Its not a serious problem at all.Its probably a small leak in one of the evap lines and you need to take it to a shop who has a smoke machine to find the leak.
Old Jun 25, 2011 | 07:07 PM
PAIXAO's Avatar
Unless youre coming up on emissions inspection I wouldnt worry too much about it, but make sure you do fix it before emissions time.
Old Jun 26, 2011 | 02:46 AM
Oh ok well I don't get emission tested here in NM so don't have to worry about emission testing thank god.
Old Jun 26, 2011 | 07:29 AM
LMG_35C's Avatar
Here's an Infiniti Service bulletin on the EVAP leak.
Shouldn't be a big deal to fix, and it is usually the gas cap. Make sure the rubber seal in the cap is clean and pliable using something like WD-40 on a rag. You can also check on the other fittings yourself but would need a smoke detector if nothing looks corroded or out of place.
Our environment will thank you.
File Type: pdf
Old Jun 26, 2011 | 07:59 AM
Ok right thanks for the info man I prob need the gas cap because usually I would hear the hissin sound wen I would take the gas cap off from the pressure and now I don't hear it
Also is this a pretty common problem with the G's gas caps??
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
esy
Sep 1, 2015 09:10 PM
Ray Feta
Aug 20, 2015 08:46 PM
poker_lamina
Aug 14, 2015 12:57 AM
